Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-21-2004, 05:53 PM
ninja_zx7r ninja_zx7r is offline
98 contour stalling
hello to all i have a 98 contour 4 cyl automatic,the car will start but will died out it only does it when you first start it in the morning once the car reaches normal temp it wont have a problem,and it has happen to me few times when coming to a stop before stoping it will stall out any help ty.
Old 09-22-2004, 11:57 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Possible vacuum leak or its time to change the iac valve.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 09-22-2004, 04:11 PM
iac
ty and could you tell me where is located??
Old 09-25-2004, 12:39 AM
ssei2 ssei2 is offline
Re: 98 contour stalling
one thing you may want to try is changing the engine coolint senser it is easy to get at right on top the thermastat houseing . it can cuse you problem and the part is cheap at maybe 13 dollors. it can also be checked with a vom. good luck
