Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-21-2004, 05:23 PM
JonRav4 JonRav4 is offline
Max tire width on 6.5" rim
Hi All,
I'm getting new tires on our '96 Rav4. The stock tires are 215/70/16. I'd like to get something a little wider to improve handling. How wide can I go with correct fit and no bulging on a 6.5" wheel: 225/65, 23560 or 65? Fender clearance is not a problem, just wheel width limitation.
Thanks in advance,
Jon
Old 09-21-2004, 07:02 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Max tire width on 6.5" rim
Goodyear makes a 235/65/16 that will fit on those rims, unfortunately, they cost $199 each and thats the only manufacturer I could find for tires in that size.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-21-2004, 09:32 PM
Rufe Rufe is offline
You could probably go as wide as a 255/series and still be within the manuf. approved rim width range (6.5 - 8.0). If you can find one.
Generally speaking, (ie: spec's may vary with manufacturer)
225/ no problem
235/ no problem
245/ you are now at the minimum rim width
255/ about max you can go, at the minimum rim width (Light truck)
Your problem is going to be finding a tire that is close to your original tire's diameter. You can go to a different diameter tire, but your speedometer and overall gearing will change slightly.
To match closer to the original wheel diameter, you might consider these...
225/70 -16 (maybe)
225/65 -16
235/60 -16
