Old 09-21-2004, 06:08 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Question Throttle body seal replacement?
BOOSTEDSPYDER showed these http://www.machv.com/throtbodseal.html
to me when I told him about my TB leak.
Has anyone ever done this and can you offer any tricks as to doing it?
My manuals are worthless as to anything about the TB except for removal and installation........
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-21-2004, 11:52 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Throttle body seal replacement?
There are vfaqs for doing it. Thats all I used. Once you get in there and see whats really going on, its all very simple anyway. The only thing that stands out in my mind is the screws that hold the TB plate on. Be ABSOLUTELY CERTAIN tat you use high strength loctite on those screws. If they come off they will go through the motor. From the factory they are "mushroomed" on the backside so they cant come out (you'll feel te resistance when you take them out). I recomend using a hammer and punch to try to replicate that when you are done. You cant be too safe there. OTherwise, its pretty straightforward.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-22-2004, 05:31 PM
Thanks kevin!!! It's just nice to have that reassurance that it's easy!!! lol
Old 09-23-2004, 03:23 AM
AF - Advisor
Its easy, but thats not to be mistaken for something that cant be screwed up. Its very important that it is done slowly, carefully, and correctly until you've done a few. But it is "easy" Good luck.
Kevin Jewer
Old 09-23-2004, 04:51 PM
Ti-I-I-ime is onnn my side yes it is.....
Another question bout it.... does the butterfly shaft get taken all the way out and do I have to worry about the outside spring and it going..BOING!! lol First thing that comes to mind is a garage door spring... friend of mine had that happen..BOING but in a much grander scale of a BOING!!! lmfao
Old 09-23-2004, 08:26 PM
AF - Advisor
You will remove that spring before you remove the throttle plate. It wraps 2 or 3 full turns around IIRC, so its got some force on it, but remaval and instal is doable. The vfaq explains in more detail.
Kevin Jewer
