Old 09-21-2004, 04:30 PM
rhibear rhibear is offline
1992 5L RS, MAF or MAP
My 92 305 RS is throwing out a code 23. Which haynes state is the Mass Air Flow Sensor code. So, I tried to find a new one, but the parts stores all say "Not Available". They do have MAP sensors, and I read somewhere that they changed to MAP sensors for TPI engines in 1990.
Also fbodymotorsports.com only seem to sell MAP sensors for 1990+ vehicles.
Does anyone know whether the 5.0L RS uses MAF or MAP???
I am so confused.
Old 09-21-2004, 05:09 PM
twdz28 twdz28 is offline
Re: 1992 5L RS, MAF or MAP
Normally when the parts stores say NOT AVAILABLE it means it’s a Dealer only part... Call you local Chevy Parts Dealer and see what they say...
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Dober89 Dober89 is offline
Yea 1990 was the year of change to MAP sensors. Just look in front of your throttle body. Is there a MAF sensor hooked in between the rubber boot and the dual snorkel piece that hooks upto the air filters??
Old 09-21-2004, 06:47 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
well, if its a 5.0L RS, its a TBI engine, i know there is a MAP sensor under the air cleaner i think??? crap cant remember, and i know built into the air cleaner there is a sensor that has an electrical connector, but i think its an air temp sensor. If im correct it is a MAP sensor on the TBI engines, and if i remember right its on the firewall, behind the intake.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 09-21-2004, 07:55 PM
Pdye Pdye is offline
You have both a MAP and MAT/IAT sensor. The Map sensor should be located on the passenger side of the firewall (by the AC). It should have a black, light green and gray wire going to it. That is where mine is located and I have a 92 RS as well. The MAT (IAT on newer models) is located in the stock air cleaner and it should have a tan and a black wire going to it.. This sensor measures the air temp going into the TBI.
Here is a link to a a vendor for the MAP sensor.
http://www.autozone.com/servlet/UiBr...EM.A.P.+SENSOR
Just copy and past it.
Phil
Sorry forgot to add that only MPFI V6 and TPI V8 models use the MAF sensor.
