Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-21-2004, 04:18 PM
pdub18 pdub18 is offline
Centerbore?
Hey guys what's up...
Why don't any rim companies put the centerbore of their rims on their sites along with the other stats?
I'm looking at the TE37 Volks but I have a centerbore of 57.1
I have no clue what the Volks have.
Also, what exactly is hubcentric?
I just haven't heard of the term, although I probably know what it is, since I've been fixing up my car in Germany and have gotten used to German terms.
If you have hubcentric rims, do you still use regular lugnuts?
I know my stock rims had little green centering rings that went around the hub.
Old 09-21-2004, 04:49 PM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Hub centric simply means the mounting hole in the back of the wheel is the same inside diameter as the nose of the axle. That centers the wheel on the hub when you torque the lugnuts up. It can either be machined to the exact diameter or use a centering ring system. Both are hub-centric.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 09-21-2004, 10:17 PM
Rufe Rufe is offline
I wish that the wheel companies would do a much better job of posting their rim specifications, it is VERY frustrating. I have skipped over several brands specifically because they did not even list offsets on the corporate web page, let alone centerbore or weight info. You might find that Google can be helpful, though.
The Volks should be fine, I think they are 64mm or larger (don't quote me though). You will need centering rings (the hubcentric rings) to match to your car. Make sure you specify this when you buy the rims!!!
To kind of restate what Luke said, hub-centric rims are centered via the center hole in the rim matching the raised circle on the axle hub, or by adding a ring that acts like a round shim to match the rim to the hub (the part with the wheel studs in it). The wheel studs only keep the wheel from falling off. This results in a perfect fit. This is opposed to lug-centric rims, which use the wheel studs to center the rim, as well as hold the rim on the car. Tire rack has a very informative tech section on their website, you might check it out.
If you don't center the rim, you could have problems, including possibly a vibration in the tire, despite it being perfectly ballanced.
Old 09-22-2004, 04:54 AM
Thanks guy!:-)
I really hope the Volks will fit my centerbore.
I'll send them an e-mail.
Again..thanks for the help :-)
Patrick
Old 09-22-2004, 10:13 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Centerbore?
If i was you, hope that they are bigger than the 57.1 and thats the same hub size i have on my cavy... my rims are 73mm bore... Call the manufacturer and they'll give it to you, but ask to talk to a tech, i got the wrong # the first time around.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
