Old 09-21-2004, 04:01 PM
WankelTII WankelTII is offline
base eclipse injector size???
what size are the stock injectors? and are they high or low impedence?
Old 09-21-2004, 04:10 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
Re: base eclipse injector size???
i think that the stock inyector in the 2g are 440 or 450 not sure
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 09-21-2004, 05:20 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
depending on what car you have... all manual turbo cars have low impedance 450cc injectors... the 1 gen automatic turbo cars have low impedance 380cc injectors, although the 2 gen automatic turbo cars have low impedance 390cc injectors.
non turbo cars have high impedance 240cc injectors...
not sure about the 1.8l non turbo or the 2.4l spyder non turbo... do a search
Old 09-21-2004, 05:35 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
so what would hapen if you put 2g 450's into an AT car? could the ECU handle the switch?
Old 09-21-2004, 07:40 PM
EclipseRST's Avatar
Banned
yes... all the computers are the same in the 2nd gen, its just the 450cc injectors flow a lot more so you can get more air flow from your car before you hit fuel cut!
Old 09-21-2004, 09:29 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
eclipserst you could get more fuel but the ecu doesnt care what the system can currently handle it just goes by the stock setup so fuel cut would stay the same wouldnt it? since its not actually topping out the injectors its just getting shut off by the ecu when it thinks its getting close.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-21-2004, 10:46 PM
kjewer1 kjewer1 is offline
AF - Advisor
Only the 1g autos have the 390s (and 13g). With 2Gs, the injector size and turbo size is independant of tranny type. All t25/450cc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-22-2004, 02:46 AM
EclipseRST's Avatar
Banned
well if thats the case then www.vfaq.com is full of shit!
What is the stock injector size on a [DSM]? Many questions of this type can be answered by the following references:Specification
1G 1.8L - ?
1G 2.0L NT - 240cc
1G 2.0L T - 450cc (manual) / 380cc (auto)
2G 2.0L NT - 240cc
2G 2.0L T - 450cc (manual) / 390cc (auto)
Spyder 2.4L NT - ?
GVR4 - ?
Old 09-22-2004, 03:31 AM
AF - Advisor
It is indeed incorrect then! 2G autos use 450s, for sure. 1g autos should be 390, I'm 99% positive on that one. But 10cc is small enough to ignore for most poeple anyway.
Kevin Jewer
Old 09-22-2004, 04:15 AM
EclipseRST's Avatar
Banned
thats what i though so i went and researched before i posted to make sure and i was wrong... well DAMN VFAQ~
