Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-21-2004, 09:59 AM
caprice lover caprice lover is offline
trans prob
i have a 93 caprice 9c1 it goes into gear but when i give it gas it goses up to around 25 - 30 mph and doesnt shift into passing gears the digital spedo is going crazy while im sitting still it flashes random numbers trip# goes up slowly miles# goes up slow idle is rough trans fluid is cherry red changed filter trans not making sounds when i put it into drive it jumps like pressure has been building up i can get up to 25-30 with ease real quick if any one can help let me know
Old 09-21-2004, 08:51 PM
CD Smalley CD Smalley is offline
Re: trans prob
Sounds like a gremlin of sorts with the VSS.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-21-2004, 11:38 PM
whats a vss and how can i fix it someone told me the prob is in the computer
Old 09-22-2004, 05:40 AM
Re: trans prob
vehicle speed sensor.
Fix is to replace it. I can't say for sure that's the problem. It just sounds like it might be to me.
Do you have a SES light and if so what are the codes?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 09-22-2004, 12:05 PM
Re: trans prob
i dont have an ses light dont no much about cars just basics
Old 10-06-2004, 03:42 PM
ses light comes on at different times during driving or idleing
Old 10-06-2004, 11:23 PM
burnM's Avatar
burnM burnM is offline
Re: trans prob
You can read your codes quite easily if it is an OBD 1 car. It should be if it is a '93.
Look under your dashboard on the driver's side (more toward the middle) and you should see a 12 pin data link (plug-in for a scan tool). If it is indeed a 12 pin connection, you have an OBD 1 system. (which is good)
Take a paper clip or small length of wire, and insert one end in the top right pin (ground). Insert the other end of the wire into the pin immediately to the left of the ground (diagnostic test terminal). In other words, the block has six pins in the top row, six pins in the bottom row. You should have the wire sticking into and out of the two last pins of the top row.
Turn the key to the on position (DO NOT START THE ENGINE!!!) and watch the ses light. You should see a code 12 right away (one flash followed by a short pause, then two more flashes in quick succession, making... well, 12). The code will repeat itself two more times. This means that the system is working. If you have trouble codes that have been stored, they will flash after the code 12. Each code that has been stored will repeat itself three times. After all of the codes have been revealed, the code 12 will flash again, and the system will repeat itself until you turn the key off.
Pull these codes from your car, and post them here. I will tell you what they mean. If you're not clear about any of this, I'll try to clear it up for you later....
Good luck!
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
