Old 09-21-2004, 10:37 AM
gfaus gfaus is offline
Blower Motor Whine
Whenever I turn my fan on a whine is coming from the blower area. It gets louder when the fan speed is increased. I've read some posts about water possibility getting into this area. I did hand wash my car a day ago so this could be a possibility. It also sounds like a bad bearing -- kinda like a bad computer fan gone bad. It still blows air.
Should I just access the blower from underneath the glove compartment and investigate for water? Or just buy a new motor and replace?
Any help would be greatly appreciated.
Thanks.
gf
-- 2000 Grand Prix GTP
Old 09-21-2004, 11:01 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Blower Motor Whine
the motor is relatively easy to get to. It is not uncommon for water or leaves/debris to get in the heater box and make noise. If you don't find anything in there, you need a motor. You might want to pick one up just in case the motor is bad, so you have it there. You can always take it back as long as you don't install it.
Old 09-21-2004, 11:32 AM
Thanks. I'll investigate and post back.
Old 09-21-2004, 11:50 AM
BIG-L's Avatar
BIG-L BIG-L is offline
Ive also read where others have had luck just pulling out the motor and cleaning it up and lubing the bushing's....Ive had great luck using DuPont Multi-Use Lubricant
DuPont™ Performance™ “Multi-Use” is a water repelling, three dimensional lubricant utilizing advanced DuPont™ Teflon® fluoropolymer, organic molybdenum, and a polymerized wax structure. This unique combination goes on wet to deeply penetrate and loosen frozen or rusted parts. It then sets up with a clean, dry, self-cleaning™ film. This dry film will not attract and absorb dirt and grime. In fact, dirt activates release agents in the lubricant causing bits of the wax layer and the contaminants to flake off. This patented technology keeps parts clean, so they work better and last longer.
ClubGP Member 6530
Since 2001
Old 11-11-2004, 09:39 AM
jjolt jjolt is offline
Whining Blower Motor
Everytime I turned on the fan, this whining noise came from underneath the glove compartment. Found out that water after a heavy rain was leaking in the blower motor. As the fan is on, squirt some lubricant (WD-40, etc.) on the shaft-no disassembly required- as the motor is spinning. Spray lubricant in the opening located in the center of the motor. This works greatly.
Old 11-11-2004, 10:00 AM
rubberman rubberman is offline
I just took out my blower motor cause of the resistor. At the time i didnt know if it was the resistor or motor. But any way i took a 9v R/C battery and hooked it up to the motor see if the motor was bad. Might want to try that to see if you get the sound.
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 11-11-2004, 10:03 AM
Re: Re: Blower Motor Whine
I found my problem. Turns out someone (me?) jammed an envelope and it slipped past the back of glove box into the blower moter. Once I took off the glove box I noticed it immediately.
Old 11-11-2004, 10:11 AM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
Re: Re: Re: Blower Motor Whine
guess it's not always good to try and push the envelope
hahahaha sorry couldn't resist. glad you fixed your problem.
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 11-11-2004, 07:47 PM
Re: Re: Re: Re: Blower Motor Whine
comon people its funny! envelope jammed in the blower motor...pushing the envelope... sigh
Old 11-11-2004, 08:56 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
blurr, put it back. It's the only blower on your car that makes noise.
Old 11-12-2004, 08:04 AM
hardy har har..if you had read the thread you would know it wasnt my car grandpa
Old 11-12-2004, 08:54 AM
I know that. GRANDPA? Want to race?
