Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-21-2004, 10:31 AM
nconco nconco is offline
Ignition will not turn
After giving a locksmith a few hundred dollars to change a 1999 regal ignition I still have the same problem. About 80% of the time I cannot turn the iginition to the off position. The key cannot be pulled out until I can eventually get the ignition into the off position. It seems that there is not enough voltage going to the ignition security system causing the ignition to lock up. Has anyone else experianced this problem?
Old 10-04-2004, 09:20 PM
rruddfan21 rruddfan21 is offline
no, but check the wiring to the ignition switch (security wiring.) if it is not getting enough current, then obviously there is way too much resistance in the wiring. if at all possible, disconnect both ends and put an ohmeter to it. if readings aren't in specifications, then wiring is faulty. too much resistance will keep the proper amount of current flowing to the ignition switch.
Old 10-04-2004, 10:27 PM
EROLEY EROLEY is offline
Angry 99 Regal Key Sticks In Ignition
i HAVE A SIMILAR PROBLEM. tHE KEY STICKS IN THE IGNITION AND IT WON'T TURN BACK ALL THE WAY TO RELEASE THE KEY. i FIDDLE WITH THE GEAR SHIFTER UNTIL IT RELEASES THE KEY. iT SEEMS TO BE MORE OF A MECHANICAL PROBLEM OR BOTH ELECTRICAL SWITH THAT ALLOWS THE IGNITION DEVICE TO RELEASE THE KEY WHEN PRPOERLY ACTIVATED.??? PAIN IN THE ARSE
Old 10-04-2004, 11:10 PM
Re: Ignition will not turn
I thank both of you for your reply. Recently I have discovered that there is a security switch right behind the key cylinder that is malfunctioning. It consists of a small steel plunger type button that is suppose to depress when the vehicle is placed in park. I found out that it is very expensive for the dealer to replace. Therefore I drilled a hole about the size of a silver dollar under the steering wheel collar. When I turn the car off, I just need to place my finger iin the hole and press this button which allows me to turn the key into the off position. I noticed that this switch becomes extremely hot. I would think the dealer would correct this without cost since it seems obvious to be a manufactured bad design and a safety hazard.
Old 10-05-2004, 12:59 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Actually, it sounds like you're all having a problem with your Park/Neutral Safety Switch. When it is working properly it shouldn't let your ignition key turn completely off until the shifter is in park. A replacement part can be had for around $20 from AutoZone and it should be in stock. Unfortunately, I'm not sure where it is located or how easy it would be to install one yourself.
Old 09-06-2005, 09:38 PM
dwaynerstone dwaynerstone is offline
Re: Re: Ignition will not turn
Did you ever get the problem fixed? I, too, have a regal with that problem.
Dwayne Stone
[email protected]
Old 12-07-2005, 09:22 AM
rzb88 rzb88 is offline
same key removal problem
I too have a regal gs 98, that the key will not always turn off all the way to come out.
Anyone figure out how to fix this?
Old 12-07-2005, 09:44 AM
regalfriend regalfriend is offline
Mine 97.5 Regal GS. When battery go's dead the key wont come out....I think its stupid. I got stuck and had to leave the car with key in ignition, while i went to the phone to call for a jump. Any intelligent theif would know to jump the car to steal it.
Old 12-07-2005, 09:49 AM
