Old 09-21-2004, 08:14 AM
brokesilverado's Avatar
brokesilverado brokesilverado is offline
broke 97 Z71 1500 not run no more
HELP ! I have a 1997 chevy 1500 Z71 that will not start. I noticed it had wanted to stall on me a wile back the it was getting harder to start. yesterday it just stalled on me out on the inter state and i got it to start again after about 15 minutes. once i got to work and cut it off it would not fire up again but if i hit it with some starting fulid it would fire up. then after a while it would quit. i am in the prosses of replaceing the fuel pump , sending unit ,distributer cap , button. do yall think this is going to fix it. plus i noticed that the fuel pump did not want to kick on till the ignition key was all the way forward just befor you were to bump the motor over. any help would be good on this subject.
Old 09-21-2004, 09:42 AM
Thunderbolt Thunderbolt is offline
Most likely the fuel pump will solve your problem. Use only an AC/Delco pump !!
Old 09-21-2004, 11:51 AM
Re: broke 97 Z71 1500 not run no more
thanks i hope so to.... I just bought this truck 3 weeks ago its got 128k on it.
Old 09-21-2004, 02:58 PM
still no go on this truck after i put a new pump and sending unit into it. got fuel to the motor and spark to the plugs but it will not stay running unless you use starting fluid then it will run for about 10 minutes and cut out. think maybe i have a bad pump from the store ?
Old 09-21-2004, 03:00 PM
how do you test for fuel pressure were do i get that tool.
Old 09-21-2004, 04:34 PM
broughy84's Avatar
broughy84 broughy84 is offline
autozone will loan you a pressure tester. There should be a fitting on the fuel rail somewhere, but I don't know for sure. Are you getting any SES lights or anything like that?
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-22-2004, 12:38 PM
ni i am not getting any lights. does any body know were i can get a nother sending unit that has 2 hard lines and 2 soft lines coming off it that would be cheaper than 368.00 bucks.
Old 09-24-2004, 04:51 PM
skipr skipr is offline
This may be a stupid question but did you replace inline fuel filter, thats what ruined my fuel pump, I didn't know there was one until it was too late.
Old 09-27-2004, 10:23 AM
yes the fuel filter is still good
