Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-21-2004, 01:45 AM
hotinaz hotinaz is offline
Unhappy guages not working
I just purchased a 94 Bonny for my daughter and the speedometer, odometer, trip set and cruise control do not work. I was told it might be the speed sensor. Is this an accurate assumption? If so, where is the speed sensor located?
Thanks!
Old 09-21-2004, 03:12 PM
Twister97 Twister97 is offline
The gauges dont work at all or do they stutter a little bit?
Old 09-22-2004, 12:22 AM
Re: guages not working
The gauges do not work at all.
Old 09-25-2004, 09:28 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
does the tach and fuel guages work, or is it just the speedo and odometer tht don't work? if it's just the speedo and odo not working then the VSS is the problem. It is located in the transmission, near where the passenger side axle shaft goes into it.
Old 09-27-2004, 09:17 PM
Re: Re: guages not working
The tach and fuel guage works fine. So I take it it's not an easy job to change it (i.e., the tranny has to come out). Thanks for the info.
Old 09-30-2004, 10:56 AM
richtazz's Avatar
no, it's actually a simple job. It's mounted on the ouside of the trans.
Old 09-30-2004, 05:36 PM
Thanks richtazz. I appreciate the info and will post the fix as soon as I work on it.
Old 12-30-2004, 06:25 PM
Well nothing worked...I put in a new instrument cluster and a new VSS and the speedometer, odometer, trip set and cruise control still doesn't work.
I'm at my wits end...HELP!!!
Old 01-09-2005, 11:42 PM
Does anyone have any suggestions as to what I can do next?
Thanks!
