Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 09-21-2004, 12:45 AM
SenseiAccord SenseiAccord is offline
DropZone or Tsudo Camber Kits, Good?
I was wondering if anyone has ever tried using and installing DropZone or Tsudo camber kits? If so are they good to use? I jsut wanna get rid of some camber to save my tires. Lemme kno on ur guys feedback about any of those camber kit brands.
Old 10-14-2004, 09:29 AM
sfenton311's Avatar
sfenton311 sfenton311 is offline
Send a message via AIM to sfenton311 Send a message via MSN to sfenton311 Send a message via Yahoo to sfenton311
Im wondering also...someone answer this guy! I here ingalls are best, am I correct? I have a 99 Si dropped 1.75 with illuminas and tokico springs...there is a camber kit on it right now but my front right top knucle ball joint is shot, and it looks as though I will need to replace the whole kit. I figure its better to have done at once then anything else. Thanks.
To get what you do not have, you must do what you have not done.
- Unknown
Old 10-18-2004, 01:30 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: DropZone or Tsudo Camber Kits, Good?
Dropzones suck, get some tokico blues.
Any camber kit will do depending on the degree of camber needed adjust toe and camber.
replacing the upper ball joint requires replacing the whole arm.
As far as camber kits go, Skunks and Ingalls........cant go wrong with these two. washer trick for the rear.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
