Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 09-21-2004, 12:27 AM
highvan's Avatar
highvan highvan is offline
Send a message via Yahoo to highvan
Alarm light in 2000 jetta
When i turn my alarm on in my Jetta, the red light beside the door lock on the drivers side, doesnt blink? I never noticed if it did before i put a aftermarket cd player in it, but i thought maybe thats why it dont blink anymore. Could the bulb be dead or maybe a bad fuse? ( i think i checked all of the fuses though) can anyone help? I want that light to blink lol
Old 09-21-2004, 02:24 PM
boschmann boschmann is offline
Re: Alarm light in 2000 jetta
Is the system operating correctly? Try locking the car with the remote w/the windows down then reach in & open it up. The LED could be dead, but usually thay last a long time.
Old 09-22-2004, 08:30 AM
highvan's Avatar
The alarm it'self is working fine, cause i have set it off a few times. Is there a way i can change the led or check to see if there is power going to it? Thanks
Old 09-22-2004, 12:51 PM
Basically there are two wires going to it, one is brown/blue & is ground all the time, the oher is green/violet & flashes 12V+ when the system is engaged. Use a LED test light when checking.
Old 09-22-2004, 04:25 PM
indianakar indianakar is offline
Unhappy
did the stereo come with speakers? maybe when they hooked up the front speakers the led wasn't pluged back, I know it sounds obvious but that's where you have to start.
Old 09-22-2004, 07:07 PM
highvan's Avatar
hmmmm, now that you say that. I did unhook the drivers side front speaker (well, unplugged it from the new head unit) cause it was blown. Maybe thats why it's not getting any power.. I'll have to check that
Old 12-18-2004, 02:54 AM
ruejima ruejima is offline
I am having the same problem when I turn on the alarm, which works fine , the red light doesn't blink. I don't even know where to look in the car to fine the fuse box, to replace the fuse and I don't know what type of fuse to use. please help!
Old 12-18-2004, 02:55 AM
I forgot to mention that the car is a 98 trans am.
Old 12-22-2004, 05:15 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
The system is working right. The light doesnt blink because the system is not fully set. There is an alarm sensor on the radio itsself, and , since you put in an aftermarket stereo- the alarm system doesnt reconize the aftermarket radio and therefor doesnt set the alarm fully. Easy way to check this is plug the stock radio in and see if the alarm sets.
