Go Back   Automotive Forums Car Chat > Mitsubishi > Lancer
Old 09-20-2004, 09:46 PM
shi shi bog shi shi bog is offline
Banned
Unhappy problem??
can someone please help me i just tried to install a k&n pod filtre on my 2004 lancer VR-X and then my car started to act funny. i reseted the ecu then it started to get better but the next day in the morning the check engine light turned on then the car started to get all jittery(unstable). so i put the stock air filtre box back on then did the reset thing then the 10 min idle and it went back to normal no more jittering. then i drove the car then the check engine light came on again and it wont go away.
whats the prblem please help
Old 09-20-2004, 10:58 PM
matada's Avatar
matada matada is offline
Send a message via AIM to matada
Re: problem??
make sure the connector on the air flow meter is secured/installed. Make sure there isn't blockage (shipping/paciking material) in the intake. Make sure nothing got stuck on the filament in the A/f meter.
If none of this works, reinstall the stock parts and see if it corrects it.
Count em.....
matada19: she die?
OoToksinoO: no, unfortunately
matada19: damn
OoToksinoO: cant win em all man
matada19: can i sig that?
Old 09-21-2004, 11:43 AM
EvoCrazy's Avatar
EvoCrazy EvoCrazy is offline
Send a message via AIM to EvoCrazy
Re: problem??
I've beem hearing problems like these comming from the K&N filters. Budt those where for the Evos, so maybe thats not it. I guess you can try a different brand.
Old 09-21-2004, 10:33 PM
Banned
Re: problem??
matada i reinstalled the stock air box but its still the same
is it the MAF sensor or could it be the A/F mixtures
Old 09-24-2004, 03:03 AM
gooseman1 gooseman1 is offline
Re: problem??
when the idle jitters and does not seems to respond.... maybe it's the Air Sensor connectors that are faulty.... check this thingy... inside there's suppose to be a small rubber washer... check if it's there.... also ... check the clip ... maybe it's loose causing it to diconnect while driving....
I use an Apexi open pod air filter ... no problems...
