Old 09-20-2004, 10:44 PM
mitsuGTvr4 mitsuGTvr4 is offline
clutch
my clutch has 113k+ miles on it, is very heavy, and lately when im putting it in second gear, i will be letting it up, and as i shift into 2nd, its hard to get it into place. do you think its time for a new clutch, and if so how much do they run?
Old 09-20-2004, 10:56 PM
3000GT_Formula_350 3000GT_Formula_350 is offline
Banned
Red face
Probably time for a new one if it's getting hard to get it into a gear, they run anywhere from $100 to $500, depending if you want OEM or upgraded. (just bought a clutch kit for $120 the other day on EBAY, got it and it's good)
Old 09-21-2004, 10:09 AM
Igovert500's Avatar
blue + red light magnet
Re: clutch
I would honestly do a drivetrain oil change first. Do a search for drivetrain oil change and you will find other threads regarding this. There is a page on www.stealth316.com that gives instructions. When I did this, the shifting inbetween gears was SO much smoother.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-21-2004, 12:38 PM
BB1970's Avatar
BB1970 BB1970 is offline
Re: clutch
i'd also check your clutch hydraulics as they can go bad at that milage too it may not be the actual clutch on its way out
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 09-21-2004, 01:17 PM
Banned
Re: Re: clutch
Is drivetrain oil the same as transmission fluid?...come to think of it, where's the transmission fluid go on a 5-Speed?? Never even crossed my mind, that would've been rough if I bolted it up and test drove it w/ no fluid in it (doing a tranny swap).
Old 09-21-2004, 01:30 PM
Igovert500's Avatar
Re: clutch
Yes gear oil(manual) is the equivalent of tranny fluid(auto)
This is the site I mentioned before, it should answer all your questions as to what fluids and where to put them.
http://www.stealth316.com/2-awddrainfill.htm
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-21-2004, 08:53 PM
Banned
Re: clutch
thanks man.
