Old 09-20-2004, 09:38 PM
jt_crx jt_crx is offline
need o2 help!
i have crx with b16 and check engine light is on for o2 sensor. i replaced both with new and light is still on. i took out hazard fuse and that didnt work to reset the code. i also disconnected the battery for about 20 minutes and the light is still on. its the only code that comes up. i just get one blink from the ecu.
any ideas?!
Old 09-21-2004, 03:19 AM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: need o2 help!
if you've replaced the o2 sensor & reset the ecu & the code is still showing,I would recommend having your ecu checked out,
or if you have another ecu,friend/junkyard...try it out & see if its shootin the same code,gl
In the process of B00stin my D
