problem with iac valve
well i dont know if im in the right forum or not but i would appreciate any hep anyone can give... heres my problem .. my engine was idleing erratically so someone old me to clean my iac valve .. so i cleaned it and put it back in .. i started up the engine and it sounded perfect.. later on i realized i forgot to plug in the electrical connector back into the iac
so i connected it and start the engine and now its idleing erratically again .. so my question is does anyone know what the problem is... or is it ok to not plug the connector back into the iac??? will that cause any problems ?? thanks |
Re: problem with iac valve
what was it idling at without the connector on?
D16Y7/D16Y8 mini-me swap turbo coming this summer |
when the plug is out of the iac it idles great and then when i plugged it back in it started idleing erratically again
ohh my bad i didnt understand ur question.. i dunno the tach is broken im waiting for a new one to come anyday now
my old engine always idled a little better when the rpm was just a bit higher... like right around the 1,000 rpm mark. maybe with the connector unplugged it is revving a little bit more and you just didn't notice
![]() LS1 RX-7 Zoom Zoom |
correct me if im wrong, but its running open loop with it disconnected which is probly keeping your idle at a nice and smooth(but high) 1500 or so
would a bad iac valve cause the cel to come on ???
is your light on when its unpluged?
Re: Re: problem with iac valve
ive got manuals 92-95 civic 96-98 Civic clicky here clicky here WTB:92-95 EX/SI cluster w/tach FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers |
thanks ill try that
I'll be your huckleberry, I.M. name on aol JncoJoker4 if you have answers to my threads |
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
m.a.p. sensor check
tomorrow i'm going to hook up a multimeter to the m.a.p. sensor to see if maybe it is failing. this maybe my problem to my iac question since i'm not getting a reading on airflow through my afc.
On my 92 civic dx, When I left the iac unplugged once, it stalled real bad so I don't know why urs is doing great. Once I stopped it wouldn't start until i plugged it back in
Re: m.a.p. sensor check
