Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-20-2004, 08:49 PM
gismo0184 gismo0184 is offline
Question eibach pro kit springs
i just bought eibach pro kit springs, eibach anti-roll kit (sways), and kyb gr2 shocks for my 97 teg. is this a good set up?? do i need a camber kit with the 1.3" drop?? are the sways as good as i've heard?? and would it be a good idea to get a master bushing set??
the difference between racing and driving.....either you can or you cannot.
Old 09-21-2004, 08:15 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Re: eibach pro kit springs
You may not need a camber kit with that minimal of a drop. The shop doing the alignment can tell you better than anyone else. It all depends on what condition the bushings, frame, and suspension is in. If you are serious about handling, the bushings make sense. They will be firm riding but will make a big difference when driving at the edge. Be prepared to lube them at least every other year or they will make noise.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
