Old 09-20-2004, 08:21 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Talking some good news...for once
just found out that my friend is GIVING (yes, FREE) me a 16g turbo no shaft play, just a little dirty...but i'm gonna clean it up...anyway it shouldn't be that hard putting this thing in, right? also how much boost should i run on this thing? i have stock injectors/pump. all i really have is a K&N filter, MBC, short shifter, and gauges. so what's a safe/good psi to be running on this 16g without anything going BOOM? lol
thanks for any help
Old 09-20-2004, 10:34 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: some good news...for once
14.
DSM geek
Old 09-20-2004, 11:12 PM
14? I'm running 16psi right now on my stock T25...
Old 09-21-2004, 02:49 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
It's a bigger turbo, so of course you are going to run less boost on it. Even lower pressure on a bigger turbo can be higher airflow, which is power. Don't mistake boost pressure for power. Anyway, you need a 2g install kit, because it's not bolton. Look at the RRE one or DSMtuners.com you can search for '14b install 2g' '16g install 2g' etc.. to see how to piece a custom kit together. All mitsubishi turbos need an install kit to go on a 2g.
Old 09-21-2004, 04:59 PM
my friend said it bolted on to his 97 GSX...maybe his mechanic put the 2g install kit on it because my friend isn't actually the one who put it on. he just took it off when he blew his motor. so if he took it off when he blew his engine up, would it all come off as one piece or what?
Old 09-21-2004, 09:40 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
depends. if you want the easy way just have him give you the whole exhaust manifold with it
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-21-2004, 09:56 PM
JoeWagon's Avatar
Banned
It bolts up to the exhaust manifold, it's just the position of the compressor output and the oil/water lines.
Old 09-21-2004, 10:01 PM
sorry i thought it needed a different exhaust flange
-1stGenRocks-
Old 09-21-2004, 10:44 PM
kjewer1 kjewer1 is offline
AF - Advisor
I like the 199 dollar "hacker/tweaker" kit from RRE. Only includes the main parts: J and L pipes, stainless oil feed, and a few small parts. The larger gaskets are all metal and can be resued many times. I reuse them until they leak. Filing out hte 2g return line bolt holes is a time consumer, a used 1g return line will save time. Its not a hard job, check out the vfaq for installing a 16g/14b in a 2g, lays it out pretty well. Theres lot of detail there, its less complicated than it looks.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
