Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-20-2004, 09:10 PM
Towlie's Avatar
Towlie Towlie is offline
Send a message via AIM to Towlie
CV joints i think
Yea so i had to restud one of my hubs
and than, i think the CV joint broke on it
well here are the symptoms
turning is ruff
i hear a thump when i got at a constant speed, and it kinda picks up when i turn
when i accel the thump goes away tho
so hmm
i dunno
Wanna get high?
Dont forget to Bring a Towel!
Towlie is off the wang wang!
Asshole Krew Member #004 We are 1337 RoXxoR and OWN JOO!
Old 09-21-2004, 12:51 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: CV joints i think
maybe CVs. they are easy to do, and don't cost as much as other cars.
check engine mounts too.(top of timing cover, bottom of timing cover, under air filter on trans, inside left wheel well on trans.)
does it make a different noise for turning left or right?
how about going up and down like on speed bumps?
do you have lowering springs?
Old 09-21-2004, 01:35 AM
Towlie's Avatar
its lowered yea, and turning its not really a dif noise? its just the same?
Wanna get high?
Old 09-22-2004, 12:29 AM
but does is the noise faster/slow on right/left turns?
try putting the stock steelies back on, see if it goes away.
lower spring wreck havok on CV joint, big time if it is more then 2"
most likey i thinking CV joints too(95% sure)
other possiblitys:
wheel bearings
aftermarket rims not a perfict fit
differential problems(very unlikey, unless the last owner dropped a $2k quiafe aftermarket differential)
