Old 09-20-2004, 07:44 PM
miah_42 miah_42 is offline
Question largest tire size
i got a stock 2003 silverado im putting a 2in coil spring lift. i dont know what tire size i can go up to. it comes stock with 235/75/16.
Old 09-20-2004, 07:45 PM
Re: largest tire size
oh i forgot to tell you all its a 2wd.
Old 09-20-2004, 09:48 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
is it just 2" in the front or what? either way you should be able to 265/75/16's on with out rubbing.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 09-21-2004, 08:03 AM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
I have 265 on mine now at stock height and it looks alot better than stock. Fills the wheel wells nicely. I'm not sure you would want to go any bigger though with just a 2 inch lift.
What kit did you use for your lift. I'm wanting to do about 2-3 inches also but dont want to spend 6-800 bucks on a kit. I was thinking about finding some 2500HD springs and swaping them in.
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 09-21-2004, 08:45 AM
Mulaka Mulaka is offline
I have a stock 1999 Z71 Ext.Cab that currently has 265\16 on it. How how can I go without rubbing?
Old 09-28-2004, 11:53 AM
ibpimpn2night ibpimpn2night is offline
I have a 1999 Z71 and I currently have 285's on it with no problems. I don't think you can go any bigger without a lift, but can anyone prove me wrong?
Old 09-28-2004, 03:20 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
so 285's would work on my blazer i suppose?
Old 09-29-2004, 03:39 PM
Blue_Villain Blue_Villain is offline
Shouldn't a 2003 be in a different area on here?
Your K5 should accept a 33 inch wheel with no lift and only a slight rubbing with extreme wheel turn and a decent bump.
The 03 (and 04-05) should accept a 285 easily as they've touted the new 20 inch rims (which need serious mods on a 4x to protect the power steering pump, but a 2wd should be fine).
Check with the people you're buying the coil from, they should know as well.
-Villain
Old 10-01-2004, 09:22 AM
Is a 33 going to look goofy without a lift, cause my money is going towards other things.
Old 10-02-2004, 01:06 PM
Re: Re: largest tire size
Well, "goofy" is a personal preference. There will be less space between the wheels and fenders with a larger wheel and no lift. You could consider a 2-3 inch body lift for no more than $200 and I don't think you'd have any problems with the style.
Again, this is personal preference... the 1993 Impala that just left my dealership with 20" rims looks goofy, but SOMEBODY liked it enough to spend that much money on them.
As far as physical specs... they'll fit. That's all I was saying.
-Villain
