Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-20-2004, 08:37 PM
ricergribbs ricergribbs is offline
Send a message via AIM to ricergribbs
how much to get an ls over 200whp?
hey im thinking about getting a crx but i want to drop a b18b1 engine from an integra ls into it and supercharge the puppy. any ideas what kind of boost id have to run? and any other mods id have to do? i was planning on getting some things for fuel management, maybe new cams, and definetly getting it tuned once its all together. ive heard the b18b can handle up to like 300hp so would i have to upgrade any of the internals? any help you can throw my way on how to get over 200whp would be a big help. and i either want to go n/a or supercharger, so please dont recommend turbo. and ild prefer to not have to have a frankenstein engine so avoid that too if you could, thnx.
Old 09-20-2004, 10:33 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Re: how much to get an ls over 200whp?
how much money u got?
Old 09-20-2004, 11:21 PM
thats not really an issue, ill save up as much as i need. but like i said i really only want over 200whp, so hopefully in the 200-250 range would be fine for me.
Old 09-21-2004, 12:34 AM
tran_nsx's Avatar
200whp all motor or 200 whp boost? since u dont want an ls/vtec, 200 whp n/a is going to be extremely hard to reach, higly expensive, and not too mention u will need professionals to help u to ur goal. i wouldn't go this route unless of course u got money, time, and know some good shops.
Old 09-21-2004, 10:47 PM
eclipse2quick21 eclipse2quick21 is offline
LS motor with SC, bolt ons, and new cams should be around 200 whp. or if all else fails SC and nirtous.
Old 09-22-2004, 12:12 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
With boost...you'll definitely see 200whp on the ls motor. All motor is possible but like trans said...its gonna be hard. If you want all motor then get a GSR motor. You saw my post when my boy put 197 to the ground. It didn't take much mods to get it up there.
Old 09-22-2004, 01:49 PM
kittedb18bt's Avatar
kittedb18bt kittedb18bt is offline
a jackson racing supercharger running at 8+ psi should get you over 200whp on a completely stock engine. do other mods and you should see somewhat higher numbers.
Co-Founder of AF V-Card Club
1999 Ford Mustang Cobra: Cobra R rims, Magnaflow CB.
"no way man...i saw an LS1 fight godzilla and the LS1 beat godzilla and it looked in the air and was like what do you think of that god and god was like bring it bitch so they fought and the LS1 beat god now the LS1 is god because its the greatest thing ever."
Old 09-23-2004, 12:43 AM
boosted k20's Avatar
boosted k20 boosted k20 is offline
Go TURBO!!!!!!!!!!
www.MEDIUMRACING.com
Old 09-23-2004, 01:16 AM
alrighty, its been decided. crx with an integra LS swap that will eventually have a supercharger strapped to it. hopefully ill get started with this project this spring/summer. prolly get the engine, car and stuff. clean up the engine with new rings/gaskets all that crap. prolly new cams too. then SC will prolly come next summer hehe. alrighty thnx for the help all.
Old 09-23-2004, 01:17 AM
oh does anyone know the compression ratio on the LS b18b1 engine?
Old 09-23-2004, 03:13 AM
mellowboy's Avatar
I believe its 9:6
Old 09-23-2004, 06:25 PM
tran_nsx's Avatar
Re: Re: how much to get an ls over 200whp?
compression ratio for the b18b1 is the same as the b18a1; 9.2:1
Old 09-23-2004, 09:48 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
tran_nsx is correct, the compression ratio for a B18B1 is 9.2:1, same as the compression ratio of a B18A1.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 09-24-2004, 12:10 AM
mellowboy's Avatar
I knew it was around there.
Old 09-24-2004, 12:22 AM
tran_nsx's Avatar
hey whats up eckoman haven't seen u around in awhile, thought u were gone, well im glad ur still here.
