Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 09-20-2004, 08:31 PM   #1
west50_1
93 lum euro 3.4 fast cold idle
93 lumina euro 3.4 on cold start- up wants to idle above 2000 rpm's until warm, than idle's down. Have replaced fast idle control did not help. any suggestions?
west50_1 is offline   Reply With Quote
Old 09-22-2004, 12:42 PM   #2
richtazz
stupidity should hurt
richtazz's Avatar
Re: 93 lum euro 3.4 fast cold idle
did you clean the IAC motor seat? and did you reset the computer so it will recognize the new part? If you did both of these, I would check for a sticky EGR valve next.
richtazz is offline   Reply With Quote
Old 09-22-2004, 05:21 PM   #3
west50_1
Re: Re: 93 lum euro 3.4 fast cold idle
I cleaned seat with carb cleaner, by reset computer do you mean unhook batt. yes. New problem, check engine ligtht, came on, map sensor. Replaced sensor, reset computer. now on occation I get a vac howl around the egr. when you put pressure on in the noise changes. Also carb cleaner will bubble at the base, but does not change rpm's
