Go Back   Automotive Forums Car Chat > Volkswagen > General Discussion
Old 09-20-2004, 07:12 PM
KAC KAC is offline
Diesel Extremly low oil pressure
Hi, how's it going?. Im new to here but I have a little problem.I have a 1.6 turbo diesel swapped into my Suzuki Samurai.I now has all of a sudden really low oil pressure. Around 15 psi warm at the filter housing, 11 psi at the head. I replaced the vaccum pump oil pump and put in new rod and main bearings. Any suggestions?
Old 09-21-2004, 01:30 PM
boschmann boschmann is offline
Re: Diesel Extremly low oil pressure
Did you measure the crankshaft with a micrometer to check if standard bearings would be okay? Minimum crank journal sizes are 2.124" @ mains & 1.880" @ rods. If you don't have a micrometer you can check the clearance with plastigauge, max wear limit is 0.007" @ mains, 0.005" @ rods.
Old 09-21-2004, 07:10 PM
KAC KAC is offline
The mains looked like no wear and the rods were in good shape aswell.I plastigaged them there were in spec.I changed them because i had them.Engine has 245000KM.so it was due.Could this be a head problem?
Old 09-22-2004, 12:20 PM
It's possible, does it have solid or hydraulic lifters?
Old 09-22-2004, 06:49 PM
KAC KAC is offline
It has hydraulic lifters.
85 Samurai with 1.6VW Cooled and tuned Turbo Diesel.
