Old 09-20-2004, 06:52 PM
transamgrrl transamgrrl is offline
Send a message via AIM to transamgrrl
Question Help! Can't figure this out...
hey all,
im in need of some help... i have a 96 trans am.
i just bought it used (86K), and there's only one thing i can't figure out.
i was going through all the odds n' ends i need to bring the car into tip top shape... but...
when the car idles, the rpms "bounce"
it's not constant, but it happens often enough. the car revs, then relaxs, and so on...
i havent notice anything unusual when driving, though it does feel like the car is holding back a little.
any idea what this is? need more info?
please help, ive been in the garage all day trying to figure this out, just cant...
Old 09-20-2004, 07:15 PM
JoeJoe231455 JoeJoe231455 is offline
Re: Help! Can't figure this out...
I know of a few things that can cause that...
#1, replace your EGR valve if you have not done so
#2, replace your pcv valve
#3, blast your throttle body with throttle body spray cleaner with the engine running, and open the butterflies just a little as you do it (dont use carb cleaner unless its marked safe for throttle bodies)
#4 - Clean your IAC
http://shbox.com/1/iac3.jpg
2001 Pontiac Grand Prix GTP
1994 Pontiac Firebird Formula
1972 Pontiac GTO
Old 09-20-2004, 10:11 PM
Thumbs up thanks so much
i cleaned the iac already, idle still rough, but i havent tried replacing the pcv or egr, ill get on top of that tomorrow and let you know how it turns out. thanks again.
Old 09-22-2004, 02:26 PM
Re: Re: Help! Can't figure this out...
awesome... its idle smoothed out completely. i installed a new EGR and just in case, replaced the Pvc too.
started her up, and running great....
thanks again!
#4 - Clean your IAC
