Old 09-20-2004, 06:33 PM
sourcelx's Avatar
sourcelx sourcelx is offline
Cool what wires what?
Im still new at working whith cars so dont get mad.
I have a 90 eclipse gs , and im tryin to install some glow pedals.
The problem is i dont exacly know what wires im suppose to hook
them up to. Im almost sure that i need to hok up it to 12v and ground
under the dash but i dont know what wires they are. Need help.
Old 09-20-2004, 06:40 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
well, you can tap into your cig lighter on your dash, then your peddles would dim with the rest of your car. any remote power would work though. and im sure you have some basic understanding of how ground wires work. look and vfaq for boost gauge install, and connect it the same way
DSM geek
Old 09-20-2004, 06:45 PM
sourcelx's Avatar
Re: what wires what?
I cant hook it through the lighter cuz it dont work.LOL ,but are you sayin to hook it up through like the dash gauges wires?
Old 09-20-2004, 07:14 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
just becaust the lighter doesn't work does not mean the wires are not 'hot' ... besides you just may need to clean it out and reconnect the wires to the lighter.
re-post and check in the Honda forum. those guy's have a bit more knowledge about glow stuff than we do
Old 09-20-2004, 10:06 PM
sourcelx's Avatar
ok, thanks ill try it.
Old 09-20-2004, 10:30 PM
lol. if i were ever going to intall glow sticks, or bug atractors, i'd just wire in a multi wire distributer, maybe a cheap 4 channel rockford for 30 bucks + wire so i wouldn't have to worry about stuff like that.
DSM geek
Old 09-20-2004, 10:58 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
is there the fusebox under the dash in the drivers side of the 1gs? in my 2g i just took the power wire and jammed it up with one of the fuses on my reverse glow gauges.. i found a screw to ground it with... i forgot wich fuse i used but whatever it is they come on and stay on when i turn it on and go out when i turn it off and well thats good enough for me...
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-21-2004, 06:05 PM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
i had to do that when i first got my glow gauges because i couldn't find a good source. Then i saw Vince's Car-Domain( thanks Boosted), and now it works like it should.
Speaking of electrical stuff... Out of everything that could cause a spark... I replaced one of my dome lights, and when i touched it to the metal in the dome, it sparked in there, and my radio, my lights, and 2 or 3 other things went dead. I noticed i left the switch for the bulb on. I shut it off, put the bulb in, replaced all the fuses i blew, and that was that. A little tidbit for those who haven't had too much electrical experience... If this can happen with a simple light bulb, just imagine what you can do if you touch two wires that shouldn't be touching.
*1997 Mitsubishi Eclipse Spyder GS /// SOLD
*1997 Jeep Grand Cherokee Limited
*2000 Chevrolet Cavalier Z-24 Convertible
My Spyder on Car Domain! Check it out!!!
My Jeep on Car Domain! Check it out!!!
