Old 02-12-2002, 05:28 AM
hondaluvr97 hondaluvr97 is offline
New exhaust rattling... any suggestions?
I got an APEX Dunk a few months ago and put it on myself. It has rattled ever since.(About when I hit 2k rpm.) I thought it was hitting the heat shield, but I took it to a shop and the guy lowered it by bending the hooks and it still does it. Has anyone had this problem or have any suggestions about where it might be coming from??? thanks
97 Accord
-All clear lights
-17" Enkei Zenkei
on Kuhmo 215 40
-DC headers
-APEXi Dunk cat-back
-Eibach Sportlines
-Bec-Tech struts
About 2in. off the ground! :smoker2:
Old 02-14-2002, 02:04 AM
ACCORDLVR ACCORDLVR is offline
the hooks are probobly the cause pf the rattle. check the rear hook (the 1 closest to the muffler) tighten it down and you should be good to go.:flash:
"Bad cop! No doughnut!"
Old 02-14-2002, 12:09 PM
easternxtreme easternxtreme is offline
Send a message via AIM to easternxtreme
did u use gaskets and torque all the pipes together right
Old 02-14-2002, 09:21 PM
I used all the gaskets, but I didn't check the torque. Do u think it might not be tight enough?
97 Accord
-All clear lights
-17" Enkei Zenkei
on Kuhmo 215 40
-DC headers
-Eibach Sportlines
-Bec-Tech struts
Old 02-14-2002, 09:30 PM
it could be a possibity, seems to simple, but u never know
i'd guess about 50 ft/lbs would be enough
Old 02-17-2002, 01:32 PM
SmokeyTheDrftr SmokeyTheDrftr is offline
Send a message via AIM to SmokeyTheDrftr
im not too sure but if you put on new bushings with the exhaust, they tend to rattle for awhile until the bushings break in and quieten down. jus my 2 cents
Old 02-17-2002, 09:16 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
I have a civic, but same principle, when i first got my exhaust, it was rattling, and I didn't know why because I used everything they (Tenzo) gave me, and it still rattled. It turns out there's a $10 piece of hanger that didn't come with the exhaust, but what it does is push the hanger away from the frame, which was what my exhaust was rattling on. The mechanic told me this when I was gettin my oil changed, and he installed it for 10 bucks, no rattles anymore.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 02-18-2002, 05:19 AM
Do you remember exactly where it was hitting the frame? I can't really tell where its coming from. I think if I knew then I should be able to easily fix it myself. thanks for your help everybody.
97 Accord
-All clear lights
-17" Enkei Zenkei
on Kuhmo 215 40
-DC headers
-Eibach Sportlines
-Bec-Tech struts
Old 02-18-2002, 08:01 AM
For me, it was in the back, where the hanger hooks to the rubber piece, on its way down, it was touching the frame,so when the car was on, and the muffler shook a little, it was banging the hanger against the frame. So check the back end of the exhaust.
35% Platinum tint
Old 02-26-2002, 03:16 AM
already answered this ?.
Old 02-27-2002, 05:26 AM
I havn't had time to work on it yet, and its too cold but I'll let ya know when I fix it. thanks
97 Accord
-All clear lights
-17" Enkei Zenkei
on Kuhmo 215 40
-DC headers
-Eibach Sportlines
-Bec-Tech struts
