Old 09-20-2004, 04:42 PM
shooterc5 shooterc5 is offline
Send a message via AIM to shooterc5
SC pulley question
On my 99 gtp i want to install a smaller pulley. Other than changing to a smaller belt can i run the 3.4 pulley with no other modifications?
Old 09-20-2004, 04:50 PM
BIG-L's Avatar
BIG-L BIG-L is offline
You can,but to futher aid in the performance of the pulley you should at least remove the U-bend in the exhaust and maybe think about either a CAI or FWI intake since it will increase more air flow.
~Larry~
ClubGP Member 6530
Since 2001
Old 09-20-2004, 05:49 PM
JoeJoe231455 JoeJoe231455 is offline
Re: SC pulley question
Yeah, what he said. Mods like the u-bend removal help ditch a little more of the extra exhaust flow, a 180 or 160 thermostat will help keep the motor cooler under the heat of the extra boost, and a cai is always a good idea to maximize gains.
2001 Pontiac Grand Prix GTP
1994 Pontiac Firebird Formula
1972 Pontiac GTO
Old 09-20-2004, 06:27 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Smaller belt will do it.
Old 09-20-2004, 06:31 PM
GTPCatz GTPCatz is offline
Banned
FYI: 3.4 doesnt require a new belt....just recommended
Old 09-20-2004, 06:32 PM
BIG-L's Avatar
Actually,the stock belt will work down to a 3.25 pulley but most seem to go with a new belt for added grip, like the GoodYear Gatorback belt and that part # is 4060660
~Larry~
Ya beat me to it
ClubGP Member 6530
Since 2001
Old 09-20-2004, 07:13 PM
stlwagon stlwagon is offline
May also want to consider a larger tensioner pulley. This will reduce slippage by causing more belt wrap around the SC pulley. Easy to install and around $20 (pulley only not the entire tensioner).
Watch out for a 160* t-stat if you live in a cold climate. Sudden rush of coolant into a very cold engine could crack the block/head. If you go with the 160, may want to consider drilling it so you get some coolant flow at all times. Otherwise, go with the 180*.
Old 09-20-2004, 11:00 PM
Thanks alot guys. BIG help i think im going to go with the same belt but a bigger tensioner pulley. I am also going to invest in a CAI whats the best one to get for the money?
Old 09-20-2004, 11:08 PM
Banned
none....make your own
FWI are the way to go...and can be made for less then 50 bucks
MY 4" FWI
Old 09-21-2004, 12:50 AM
Thats sounds pretty good. What did you make it out of and how did you make it if you dont mind me asking. Im more interested in the FWI than the CAI i think.
Old 09-21-2004, 09:34 AM
BIG-L's Avatar
Here are a few set's of instructions for an FWI....~Larry~
http://tacgp.clubgp.com/custom_mods/...ake/index.html
http://www.johnvegas.com/Fwi.htm
http://home.centurytel.net/grandprix/fwi/
ClubGP Member 6530
Since 2001
Old 09-21-2004, 10:16 AM
Thanks alot larry. Couple of other questions (not trying to be a pest) ince ill be getting rid of the stock air box what should i do with the pcm? And also what what about those rainy days? I live in michigan so we have alot of snow sometimes and always have those ocasional rainy days. I dont wanna accidently hit a water puddle and soak the filter with water or the PCM for that matter. Any suggestions anyone?
Old 09-21-2004, 11:27 AM
BIG-L's Avatar
You can get a PCM tray from a 2001 blazer that will work to hold your PCM when you install a Fenderwell Intake or CAI,from either a salavage yard,dealer or the below web site.Not sure about the water with the FWI since ive had a MSP CAI on since 2000,but Im sure Catz can tell you.
~Larry~
Part # 15995679 www.gmpartsdirect.com $15.80
Old 09-21-2004, 12:45 PM
Obviously you have been doing this a long time Larry. Would you recomend a CAI or FWI? Pros & cons? Im not sure what i want to do yet. I like the FWI because of the low cost to make but im worried about getting the filter soaking wet in the event of a rainy day. Do they both offer the same amount of performance gain? Your opinion would be much appreciated. Thanks
Old 09-21-2004, 01:49 PM
2kBlkGTP 2kBlkGTP is offline
i have had a FWI for about a year right now...if you make the tubing out of 2 pieces you can change it from a FWI to a short ram. I never had any problems with getting water in the FWI btw and niether have all my friends who have mustangs
