Old 09-20-2004, 04:16 PM
jncodave jncodave is offline
parallel/parallel
i have a 1 ohm stable amp and am pushing 2, 10 inch 4 ohm dual voice coil subs with it. it is currently running in series/parallel so the impedence is 4 ohms. i was wondering if i could run it in parallel/parallel so that the load would be 1 ohm. can i do this and if so how do i do this?
Old 09-20-2004, 04:20 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Re: parallel/parallel
Of course you can do that, although depending on what subs and what amp, you may not want to do it. But anyways just run the positive from the amp to both positive's on each sub and the negative from the amp to both negative's on each sub.
Here check this out...
http://www.crutchfieldadvisor.com/S-...pedance=DVC4x2
Old 09-20-2004, 04:40 PM
ok thanks for the help
