Old 09-20-2004, 03:43 PM
tsi95 tsi95 is offline
Unhappy high idle
i have a 95 tsi, and it idles way to high. it's supposed to idel close to 1,000 rpms, but its reading 1,500 to 2,000 rpms when idle. this only happens when i'm in park. when i put it in drive or reverse the rpms go back to normal. does anyone know what is causing it to idle so high?
Old 09-20-2004, 03:45 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: high idle
I think its supposed to idle kind of high when you turn on the engine after a significant amount of time leaving it off...mine idles around 1200 rpm when turning the engine on for the first time before letting it "warm up"
Old 09-20-2004, 03:52 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: high idle
idle surge......
Old 09-20-2004, 05:44 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: high idle
I have that problem... mine is from the seals on each side of the TB plate/butterfly and since they are worn it leaks boost and has affected its idle speed. I got new seals on the way!!!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 11-17-2004, 06:02 PM
BlackEclipse97 BlackEclipse97 is offline
Banned
Send a message via AIM to BlackEclipse97
Re: high idle
ok yes i brought this thread back, but it isnt even 2 months old so i think im ok, but my car has this problem it idels 1.5 grand and i was wondering if there could be anything wrong with it besides what he ^^^ said or could explain what he ^^^^^ said in english lol i dont know what he is talking about what are Ecplises suppose to idel at?
Old 11-17-2004, 08:06 PM
joemathews's Avatar
joemathews joemathews is offline
Re: high idle
Sometimes just adjusting the throttle cable does the trick.
1996 Eagle Talon
Old 11-17-2004, 10:22 PM
Banned
Re: high idle
really?
Old 11-17-2004, 10:29 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: high idle
yea adjust the cabkle when the car has heated up. once the cars hot turn it off and have somebody sit in the car and press the gas to the floor. while they hold the gas down you move the throttle cable bracket until the throttle is wide open. tighten down the bracket and then you should be good.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-18-2004, 03:04 PM
Banned
Re: high idle
ok ill try that, it sounds easy enough thanks a lot
Old 11-18-2004, 04:39 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: high idle
try checking for a vacuum leak. i had to replace a vacuum hose one time and i just left the car running and when i pulled off the hose, the car rev'd up a little bit and stayed there for awhile and came down really slow. do a vacuum test, you might have a faulty/disconnected hose.
95 Talon TSI AWD
97 Eclipse GST
Old 11-18-2004, 06:04 PM
pro3racer pro3racer is offline
Yep, thats what i had, my idle surge is from 1000rpm to 1500rpm, and adjusting the BISS did nothing, so i check for a vacuum leak, and i found 2 hoses coming out of the thermostat, going into the throttle body/ISC. I plugged them up for now, and i'm replacing the hoses tomorrow. I hope that makes it all good.
Old 11-19-2004, 02:35 PM
Banned
Re: high idle
ill try that also lol when ever i get time im going out of town this weekend though so hopefully monday! plus i have to watch my Buckeyes against Michigan booooo lol we will probably get our asses kicked this year though
Old 11-19-2004, 03:19 PM
Banned
Re: high idle
i just went out and adjusted the BISS and it seems to have fixed it but i will see if it stays fixed lol if not ill check the vac hoses
Old 11-19-2004, 03:25 PM
I first adjusted the BISS, but that did nothing, because of my vacuum leak, but the idle surge worse now, and my idle is higher, so i'll have to readjust it after the new hoses are in. BTW, can i just screw in and out the BISS, or do i really have to go and find all those plugs and ground them??
