Old 09-20-2004, 03:07 PM
Figori's Avatar
Figori Figori is offline
Send a message via Yahoo to Figori
Sunroof Q
What is the procedure, in lamen's terms, on how to remove the sunroof panel and rails? Mine sticks just a little bit, and I am hoping to be able to remove the rails and such and clean them. I know Turtle did it.. Just curious. And yes, I know this is the wrong forum, but I'm looking for answers, not "I have no idea" 's.
"Short, sweet, and to the point"
1987 CRX Si - Project Si 'RexSi'
1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL.
2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ?
Old 09-20-2004, 03:14 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Sunroof Q
theres a sunroof forum? ::scratches head::
Old 09-20-2004, 04:41 PM
Figori's Avatar
Re: Sunroof Q
I have an '87 CRX Si. :P
Old 09-21-2004, 03:23 AM
Forunn Daberator
Re: Sunroof Q
ah, didnt notice. I asked someone and they said you have to take out the headliner and once you do that its pretty clear what to do as you can see all the parts.
Old 09-21-2004, 08:25 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Sunroof Q
Actually, it's a bit tricky, but on the 2g crx si what you do is open the sunroof up, unbolt what you can see, then close the roof some and you'll notice a little more play in the "sticky" sliders (stupid me couldn't leave it alone and yanked it all out cuz I already had plexiglass replacement in hand... I'm a moron) and if you notice the pop up part of the slider can be opened or closed at will. If it's the rail mechanism that's sticky then grease it and put those bolts back and be on your way. If you want to replace it, you basically have to break stuff or remove the whole headliner and keep a couple of boxes handy to put like a gazillion bolts in to keep track of them. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-21-2004, 10:54 AM
Figori's Avatar
Re: Sunroof Q
Yeah, I figured it wasn't going to be easy, and I figured I would have to take the headliner out, I just wanted to hear it from somebody who's done it before. Anyways, it pops up fine, and slides back until it gets just about all of the way back and then starts to bog down. Then, when closing, it seems to bog down all of the way until it gets to the front, then drops down just fine. So I guess I can just pull it out to clean/re-lube the rails and sliders. Do they make replacements for the sliders? (the pieces that sit inside of the rails) I think I stripped the threads on one of them....
Old 09-21-2004, 05:03 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: Sunroof Q
My '86 CRX SI has the same problem. Once a year (I use my sunroof alot, even in winter) I clean it out with spray solvent then re-lube it and it works like new again! What hapens is that when the sunroof is open, you get all sorts of dirt and crap stuck in the tracks which causes the grease to get sticky. You should be able to clean it up without removing the sunroof. I usually just lube mine up with WD-40 since it seems to go longer without getting sticky. Don't use white grease, I did this once because it was what I had nearby and after about 3 weeks of gettin' dirty it just about turned into glue!
Anyway, to remove the sunroof you will need to pull out the headliner in order to gain access to all the bolts.
P.S. I know this is the wrong forum for first gen CRXs, I just happened to be brousing.
Old 09-21-2004, 11:04 PM
Figori's Avatar
Re: Sunroof Q
It's okay. I posted on the wrong forum myself just to see if Turtle could help. No harm no foul.
Old 09-22-2004, 07:31 AM
Re: Sunroof Q
Sorry I couldn't be of more help. Someday I'll redo my custom sun/moonroof and show something I'm happy with.
2010 Honda CR-V EX
Old 09-22-2004, 12:31 PM
Figori's Avatar
Re: Sunroof Q
*chuckles* I'm just happy someone else messed up and could tell me what not to do. No offense.
Old 09-22-2004, 12:37 PM
Re: Re: Sunroof Q
No problem... I'm on my 3rd custom plexiglass moonroof... the first one flew off the car cuz it wasn't bolted well enough... the second one started to crack near the mounting bolts through the roof and so I replaced it... the third one got f*cked up by my friend while trying to manually resess the mounting bolts instead of simply using non-ressessed bolts (ugh!) and now it's bubbled up, cracked all to hell and leaky. I wish I kept #2 (I thought I did... must investigate)
BTW... custom moonroof shaved off lots of weight and I can see out of it without opening it
2010 Honda CR-V EX
Old 09-22-2004, 01:25 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: Re: Sunroof Q
http://www.binghamtonlife.com/manual/2gsm/body.htm
there is a sunroof section there. i'm not going to post up all the diagrams, it's a big section. l0l
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-22-2004, 02:43 PM
Figori's Avatar
Re: Sunroof Q
Thanks Ami. YOU'RE MY HERO!
Old 09-22-2004, 03:11 PM
amy@af's Avatar
Re: Re: Sunroof Q
lol, i woulsn't go that far
http://www.binghamtonlife.com/manual/manual.htm
thats the link to the whole manual. know it, love it, pass it on!
Old 09-22-2004, 03:12 PM
Figori's Avatar
Re: Sunroof Q
Now, if you could just change my user name from Fibori to Figori, I would worship you for life...
