Old 09-20-2004, 10:33 AM
ale_k300 ale_k300 is offline
Injector Problem??
First thing guys, sorry for my english but is not my native language...
Now my problem, i got a Spyder 97 GS that has been failing a lot like the injectors were clogged... i got the check engine light, i put some cleaner on my next tank and it fixes it .... for 2 weeks, then again same thing for another 2 weeks, and now 1 week.... any idea of what can it be???
Thanks.
Alex.
Old 09-20-2004, 10:38 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Injector Problem??
Have someone at AutoZone pull the codes to see what your CE light is indicating.
Kris
2012 Genesis Coupe 2.0t
Old 10-01-2004, 10:10 AM
Code is P0304.
Old 10-01-2004, 10:54 AM
kjewer1 kjewer1 is offline
AF - Advisor
CYL 4 misfire. Most likely ignition related, the ijector cleaner was most likely a fluke. Try a new set of stock type plugs gapped properly. If that doesnt help, new wires, or borrow a set from someone else that is known to be good. Let us know how that works
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-19-2004, 07:31 PM
BRONKA BRONKA is offline
I've come across this on a chev, if your number 4 is at the end of your fuel rail, it may be filled with dirt. I had to remove the whole rail and blow it out. Something else to try.
