Before I bought my Neon I test drove it and the AC worked great, but now (2 weeks later), it doen't work at all and hasn't since I brought it home. The air blows and everything but its not cold, it basically just vents the air from outside. I realize there are multiple causes for this, but what are they and which is the most common so I can start checking for it? Thanks in advance.
Re: Any Ideas whats going on with my AC?
Check the condenser, which is directly in front of the radiator for leaks. They usually leak around the area where the lines go in. Look for a oily spot.
bring it to a shop who services a/c the can usually check for leaks and repair they also use a dye for future problems
ill go ahead and take it to a place, I realize that businesses are different everywhere, but are there any national chains or whatever that you would recommend?
I had the sam problem with mines. Ended up being a shorted AC line wire. I'd take it ni to a shop or dealer... might wanna try an AC shop first.
