Old 09-20-2004, 02:08 AM
anonymous_1 anonymous_1 is offline
Send a message via AIM to anonymous_1
how do i know if my timing is right
hey i have a 89 civic hb si. how do i check the timing belt. im not sure if thats it, i mean i drive it and then it just dies but then will start back up. i press on the gas and have to keep pressure on it to rev it up and takes awhile. anyhelp would be great
Old 09-20-2004, 02:42 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: how do i know if my timing is right
sounds like a fuel problem. Give it a good tune up, air filter, fuel filter, pcv valve, spark plugs/wires, distributor cap/rotor.
Old 09-20-2004, 04:43 PM
do u think it might be the timing at all? and if so how do i check it
Old 09-20-2004, 06:45 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Go get yourself a timing light from autozone, start the car up, and there should be 2 marks on your cam gear, when the light flashes on the cam gear, the two marks should line up horizontally with the block maybe even slightly tilted towards the front of the car if I can remember the si is a little different. And also, look down at your crankshaft pulley, there should be 3 marks by themselves, and then one white mark (towards the back of the car) on the pulley. Right above the crankshaft pulley there should be a crosshair looking extrusion from the timing belt cover. When you have the car running and the light should blink when the middle of the 3 lines are in the "sights."
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 09-21-2004, 02:12 AM
i had a 1.5 motor in there dual point. well we converted it over to 1.6 motor (si) but left it dual point would that be the problem. he said that there wont be a problem but im a new guy with the hole car atmosphere.
