Old 09-20-2004, 12:57 AM
djmavis djmavis is offline
Cool Chirping noise from rear
I have a 2WD '01 S-10 with manual transmission and the small 4 cyl engine. Upon acceleration in 1st and 2nd gear, I hear a chirping noise that sounds like it is comming from behind me. The rate of the chirping noise correlates with wheel speed, but disappears when the clutch is pushed in. I noticed it at first after long trips on the highway, but it has gotten much louder, and I hear it pretty much every time I accelerate. Any ideas?
(thanks in advance!)
Old 09-20-2004, 09:32 AM
Mikado14 Mikado14 is offline
Re: Chirping noise from rear
Check your U-joints on the drive shaft. The best way is to drop the drive shaft and inspect. More than likely you will find that they are dry and more than probably there is wear.
Old 09-20-2004, 09:42 AM
I am not much of a mechanic...Is there a place to read up on how to do this, or should I just take it to a shop?
Old 09-20-2004, 10:20 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Take it to the shop.
You sure it only stops when you push in the clutch?
Old 09-20-2004, 10:22 AM
yes, it definately stopps when I push in the clutch. I should point out that I am not certain that the noise is comming from behind me...it just sounds like it...Maybe my ears are playing tricks.
Old 09-20-2004, 10:25 AM
BlazerLT's Avatar
AF -Advisor
At what speeds will this happen?
Old 09-20-2004, 12:28 PM
up to about maybe 20 mph i hear it but not after. Im not sure if it goes away or just gets drowned out by the sound of the engine and whatnot.
Old 09-20-2004, 04:20 PM
BlazerLT's Avatar
AF -Advisor
But it comes back when you release the clutch though right?
Old 09-21-2004, 09:45 AM
correct. it only makes the noise with the car in gear, clutch released at low speeds.
Old 09-21-2004, 10:33 AM
BlazerLT's Avatar
AF -Advisor
Grease your U-Joints.
Have you ever greased your front end?
Old 09-21-2004, 12:45 PM
ok i will try that. no i have never greased the front end, but im guessing it was done at some point when the car was in for an oil change.
Old 09-21-2004, 12:58 PM
BlazerLT's Avatar
AF -Advisor
Assumptions is the mother of all repair jobs.
Do the grease work yourself and be sure. if not, don't complain when your front end is shot.
Old 09-21-2004, 10:19 PM
nhsyogi nhsyogi is offline
did you check the rear end? my s-10 was doin the exact same thing and it turned out it was the rear end. i fried mine and now i got a $700 dollar repair bill for a new rear end :\
Old 09-23-2004, 10:28 AM
i took it to the shop yesterday. they said it is likely the throttle bearing, and not to worry about it until a.) it gets REALLY REALLY loud, and/or the car stops moving or b.) the clutch needs to be replaced. They said that the throttle bearing comes in the clutch assembly kit, and that taking that apart to repair it before it was truly broken was unnecessary. How does that jive with you guys? Is that good advice?
Old 09-23-2004, 11:07 AM
BlazerLT's Avatar
AF -Advisor
Did you even have them check the driveshaft and U-Joints?
