Old 09-19-2004, 11:29 PM
artistic's Avatar
artistic artistic is offline
Air filter necesary?
I have an old brigs and straton go kart engine probralby about 3-4 hp. And there is no air filter. Attacthed to the carb is a long tube that was cut and i believe there used to be an airfilter. My question is would it really fuck up the engine if i dont put a filter on? I can easily fabricate one but I was just wondering if it was necesary. Also, would it be better without , because there would be no restricted flow?
Old 09-19-2004, 11:55 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
would you run your car without an air filter ?
Team Lonely Drivers
Old 09-20-2004, 12:02 AM
artistic's Avatar
No, but car engines are more complex than go kart engines.
Old 09-20-2004, 01:15 AM
Rufe Rufe is offline
Yes, but car drivers are more complex than go kart drivers.
Seriously, the dirt that gets into the carb and engine makes this a no-brainer. If you want it to last, get a filter.
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Air filter necesary?
A filter shouldn't restrict it too much if you get a good one. I wouldn't run it without, you'll get sh*t in your motor like dirt, pebbles, and leaves. Even though it's not a car engine it is still and engine and any debris that gets in there has the chance of messing stuff up.
