ok i have a 94 nissan altima and i just bough it a couple weeks ago and we have replaced everything that you could think of when i got the car it was running and we replaced the throttle sensor now it won't start so put the old one back in and yet it still doesn't start if you idle it it will stay on but once u let go of the pedal it's done for...i replaced the mass flow sensor ...oil...spark plugs..checked compression...all the vaccums.....what else could i do i can't drive it to go get diagnostic checked cuz it's not moving .....someone help me i need my car to work!! please!
could it be the ecu? what does that do ? would the car even start if the ecu was fried? e-mail me if not replyed to this [email protected] someone help! |
Re: my car wont' start!!! help!!!
your tps voltage when back probbing the wires should be 0.42 - 0.48 volts after that check you ditributor take the cap & rotor off clean the little plate off
96 gt bbk x-pipe lakewood traction bars american thunder cat back march ram air k&n richmond gears 97 maxima in progress |
See oil leak thread
I have a 96 Altima that is leaking oil into the distributor.. Take your off and look for oil!
