Old 09-19-2004, 10:09 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
clutch problem
ok this happened i was out of work on saturday, and when i was on the car i noticed that the clutch was half way down i can turn on the car but, the gears dont go in. i also put the car in reverse and tried to turn it on and it would roll back i also tried in first and and the car rolled forward. <<(the car was off when i put it on gear then tried to turn it on) so should i replace the clutch or what could be the problem? my car is an 87 mazda RX7 N/A with hydraulic clutch
Old 09-19-2004, 10:44 PM
Rufe Rufe is offline
Is the clutch pedal working normally?
You should be familiar with how it engages, is it different?
Describe please.
Old 09-19-2004, 11:03 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you say that when you turn the car on in gear it rolls with that gear, now is do you have the clutch pedal pushed in or not ?
Team Lonely Drivers
Old 09-20-2004, 10:58 AM
Horrse's Avatar
Horrse Horrse is offline
Send a message via MSN to Horrse
Re: clutch problem
You should check the fliud in the clutch resivour (if it's a hydro), and if it's low or there is none you need to bleed the clutch or adjust the cluth calbe if it's a cable tranny.
Horrse???
Alias: Horrse
