Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 09-19-2004, 10:02 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
Clutch Problems
ok this happened i was out of work on saturday, and when i was on the car i noticed that the clutch was half way down i can turn on the car but, the gears dont go in. i also put the car in reverse and tried to turn it on and it would roll back i also tried in first and and the car rolled forward. <<(the car was off when i put it on gear then tried to turn it on) so should i replace the clutch or what could be the problem? my car is an 87 RX7 N/A
Old 09-20-2004, 03:40 AM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
Re: Clutch Problems
check for leaks on your clutch master cylinder .
looks like you have a leak or just dont have put fluid in it.
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
