Old 09-19-2004, 09:24 PM
GARY BRUNGARD GARY BRUNGARD is offline
Question Tranny/rear
I'm having a serious rattle vibration when driving on level ground when crusing at speeds above 40. The sound comes and goes in rythem it is hard to pin point while driving but it does not sound good. My truck is a 98 K1500 silverado with a 4l60E trans and a 10 bolt rear.
Old 09-19-2004, 10:01 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: Tranny/rear
quite likely it could be bad U-joints, and thats what you should hope for cuz its the cheapest problem to solve. i had this problem with mine and they had to be replaced.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 09-20-2004, 09:11 PM
Hey whats up, did yours make a vibration/sound also.I think I know how to test the u joints but how did you determine the problem?
Old 09-20-2004, 09:47 PM
Re: Tranny/rear
it made really loud clunk upon sharp acceleration and then would vibrate while under power. i just knew it was either that or coupler and the coupler would be a lot harder fix and u-joints are cheap and easy to replace anyway. also on mine the drive shaft seal goin into the rear-end is cracked and leaks gear oil, so if yours leaks to either fix that too or feed it oil.
HD chassis package
Old 09-21-2004, 09:11 PM
Thanks for the advice I am going to replace the u joints any way but at the end of the tranny should it be damp to wet with fluid I guess it is the packing seal leaking a little? Is that normal.
Old 09-21-2004, 10:30 PM
xcaret xcaret is offline
My 1980 K 20 4x4 is at the machine shop as I type this ,for the same thing your truck is doing ..i jacked up the back end and put the transfer case in low and the transmission in drive so as tohave the drive shaft turning slowly ..I couls see the drive shaft was turning in an oval pattern and when I held a stick ou to it the noise was intermitant as it only hit the stick once every reveloution ..In my case I need the drive shaft and yoke cut and re welded dead on ..it was welded up before in the bush and I never took it in till now to get it done properly.
Old 09-21-2004, 10:34 PM
Re: Tranny/rear
Forgot to mention your leak at the back of the trans ..no this isnt proper ( maybe normal but not proper) this seal is not hard to replace ,but if you arnt showing any drips on the ground forget it ..just check trans level now and again ..what you need to do is wiegh the price of trans fluid against the cost of fixing it ..And be thankfull its not the front seal leaking
