Old 09-19-2004, 09:10 PM
RomainDeaMarchi's Avatar
RomainDeaMarchi RomainDeaMarchi is offline
Need help with buying datalogger
If i was to buy a datalogger to tune my S-AFC, which should i get? DSMlink or the OBDII. Also, if i were to get DSMlink, which package should i get? The same with OBDII, there are dif packages but im not sure on which to get. I got a laptop to hook it up too. Could i buy just the cable cheap and download the software? I need some help here, Thanks. 96' GS-T 16g turbo with 550cc injectors.
Old 09-19-2004, 10:52 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Need help with buying datalogger
I don't know what you mean 'tune the AFC'. You need either an AFC/logger combo or DSMlink, which is both. If you buy DSMlink, you won't need the SAFC. I take it by 'OBDII' you mean a datalogger. There are no packages for DSMlink. You get a V2 DSMlink software and the harness. There is no way to get it cheaper, either.
Old 09-20-2004, 01:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
Witha 96 there is almost 0 chance you have an EPROM ECU. Ideally you wuld purchase one and run DSMlink. To us the AFC, you need a regular OBD2 logger, I think most poeple use www.pocketlogger.com for a palm pilot. There are various other loggers out there for both the palm and laptops, a search on tuners will probably bring up some other brands.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
