Old 09-19-2004, 09:34 PM
alphalanos alphalanos is offline
Can I....
If I have two 6x9s that can handle 50W RMS, and a 4ohm impedance each, and my amp is:
100x2 @ 4ohm
150x2 @ 2ohm
is it possible to run my speakers safely off this amp? Like hooking both speakers to one channel?
96 EJ6. Future home of boosted B18C1.
Old 09-19-2004, 09:59 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Can I....
It is possible... Depends on how well you know what you are doing though...
www.cloudcity.deviantart.com
Old 09-19-2004, 10:27 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Re: Can I....
What kind of speakers... are they over rated? I would probably go against doing that, unless you are really good with your gains.
Old 09-20-2004, 03:46 PM
loismustdie loismustdie is offline
Re: Can I....
100x2 @ 4ohm
150x2 @ 2ohm
what brand speakers?????
the aquabats are seriously the best band in the world
Old 09-20-2004, 03:56 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Can I....
If they start distorting then turn it down, it's as simple as that. As long as you have them highpassed below ~100hz you should hit the mechanical limits of the speaker before you hit the thermal limits, which goes back to what I said at the beginning....if they start distorting then turn it down. No matter how much power your amp is capable of delivering, the speakers will start distorting at the same power level, and as long as you turn it down when you hear this happening you won't have any more problems with a 2000x2 amp than you would with a 50x2 amp.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-20-2004, 11:17 PM
Alpine Type S 6x9 coaxial
Old 09-20-2004, 11:18 PM
Haibane's Avatar
Re: Can I....
follow sr20's advice, should be fine
Old 09-20-2004, 11:44 PM
so it should be alright with one speaker per channel as long as the gain is carefully set, correct?
Old 09-20-2004, 11:52 PM
Haibane's Avatar
Re: Can I....
yes
Old 09-20-2004, 11:53 PM
sr20de4evr's Avatar
Re: Can I....
it should be fine, I have ~250x2 powering a set of 100rms components, and I know a guy who has a 500x2 amp on a set of 150rms components. Just don't get giddy with the volume knob and you should be fine, and remember if you hear them distorting, turn it down.
'01 Black Sentra SE
'05 Silver WRX STi
