How in the world does one get access to the front turn signal lights (not the ones on the side)? It looks completely sealed up and I certainly hate the thought of paying the dealership to do this.
Thanks! |
Re: Replacing front turn signals
Remove the headlamp assembly.
1.Remove the three bolts retaining headlamp assembly to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle. 2. Turn signal lamp socket and wiring assembly 1/2 turn counterclockwise and remove from turn signal lamp housing. 3. Replace bulb and reinstall reverse of instalation. The headlamp assembly reataining bolts should be 10mm.
Thank you for your help! Your directions were great.
Re: Re: Replacing front turn signals
I've been trying to figure out how to access the turn signals also. That's why i came to this forum for answers. I'm gonna try your suggestion also.
Get back at ya! HOLLA! -Rich |
I see the three bolts. Where is the pich bolt, is it the same color and size?
I figured it out. This is a great place to come for answers. Better than a Mechanic. Thanks forum.
-Roccer |
