Old 09-19-2004, 06:29 PM
MrBB's Avatar
MrBB MrBB is offline
Engine Ticking/Chatter please help
I have recently started to hear some loud ticking sounds coming from what seems to be under my valve cover. I think it may be improperly torqued valves, but I am unsure. The engine only has around 5k miles on it. Any help on what this sound could be is greatly appreciated.
Old 09-19-2004, 06:44 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: Engine Ticking/Chatter please help
What is the model and engine? What type of gas do you use?
Old 09-20-2004, 03:01 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
before you panic spring for premium gas a few times, see if that makes it go away.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 09-20-2004, 08:16 AM
MrBB's Avatar
It is a 94 supercharged 3.8L and it has premium gas in it. Vortech suggested that I use it.
Old 09-21-2004, 10:58 AM
Mendari Mendari is offline
It's a 1994 with only 5,000 miles on the engine. So the engine is new? What's the engine's architecture? Pushrod or Overhead Cams?
Old 09-21-2004, 11:22 AM
MrBB's Avatar
Yes it is new, I was one of the many people who had their head gasket fail and thus lost the ability for my engine to cool itself and had some heat damage, so I just replaced it. It a completely new motor minus accessories and other stuff that was transferred to this motor. It is a stock replacement motor for a 1994 3.8L Mustang. So later my parents suprised me with a supercharger for a graduation gift. The motor was installed by a local Ford dealership. The superchager was installed by myself and one other person who has installed Vortech products before. Earlier today I tried a half tank of 93 octane gas vs the 92 I used before, but did not have any different results. The ticking/chatter sound is made whether the engine is cold or hot.
Old 09-21-2004, 01:20 PM
You sound like a bright kid, so you probably already checked the oil level. The Vortech probably needs about 1/2 a quart extra. How about adjusting the valve rockers?
Old 09-21-2004, 03:01 PM
MrBB's Avatar
HEH, I figured out my problem. I never thought to check because it didn't sound like gases leaking.... Cylinder 1 spark plug had worked its way out somehow.... Just to the point where the gasses could get out between the threads. I still can't figure out how, but it did... I feel like an idiot. It sure had me worried though! Thanks for your time and input.
Old 09-21-2004, 03:34 PM
way to trouble shoot. now i too have learned from this experience.
free hypsi87!!
Dan's White Horse
Old 09-21-2004, 04:10 PM
Double-check all of the plugs to make sure that they are all the correct type ( flat vs. tappered ). If one spark plug shook loose, then the others might too.
Old 09-21-2004, 04:12 PM
MrBB's Avatar
I did and the rest are still tight! Thanks!
