Old 09-19-2004, 05:26 PM
ToyRex ToyRex is offline
Check Engine Light
I have a '90 Crx dx. The check engine light comes on only after driving on the highway, not driving around town. Then when I turn the car off the light stays off. I didn't have this problem until I installed a short ram air intake, but that was 3 months ago. The problem started two weeks ago. I took it to several garages, but they won't check it. I can't take it to a Honda garage because they are closed when the enigne light decides to come on. The Honda garages say that it has to be on to read the codes. The car runs fine when it's on. Any ideas on what the problem could be?
Old 09-19-2004, 05:34 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Check Engine Light
well the code will actually save in the ecu, wether or not the light on the dash is on or not. pull up your passanger side carpet under the dash and locate the red light, count the number of flashes, then tell us what it says, and we can help you from there.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-19-2004, 05:40 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Yep, it's easy. I'm surprised the honda place told you that it had to be on. Those honda dealerships are getting a bit fruity lately.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 09-19-2004, 05:42 PM
I checked the red light it flashes one time.
Old 09-19-2004, 05:48 PM
Shaguar47's Avatar
That means "Oxygen Content"
Old 09-19-2004, 05:54 PM
So what exactly does that mean? Does that mean that the 02 sensor is bad or that a vacum line is leaking. Is the problem related to the new air intake.
Old 09-19-2004, 05:55 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: Check Engine Light
wut r u supposed 2 do? leave ur car running outside while you talk to the service advisor so the light doesnt shut off?
Old 09-19-2004, 05:56 PM
1PhatCX's Avatar
o2 bad
Old 09-19-2004, 06:03 PM
Shaguar47's Avatar
Re: Re: Re: Check Engine Light
LOL, it wouldn't surprise me if you had too.
Old 09-19-2004, 06:58 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Lately?? Most of them talk out of there ass since the begining of time.
Old 09-19-2004, 09:53 PM
JDMrexBoi's Avatar
JDMrexBoi JDMrexBoi is offline
Banned
bad connection or get a knew 02 sensor and then reset the ecu and it will clear up .
Old 09-19-2004, 11:44 PM
Hybrid1990crx's Avatar
I had this problem after intalling my header. I just did a shit job of wiring and some of the wire got stripped and was grounding out on the chasis or something. So I did a good job wiring it and never had a problem again.
Old 09-20-2004, 10:05 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Even with bad O2 sensor the car will run. I had to play Sherlock Holmes for like 2 years with wiring and other BS to find shorts. I think possibly, after resetting the ECU this time it may have stopped blinking... (haven't looked yet). This passed storm has caused some problems. I think water got in through the door jam and got to the main relay... not sure, but my car was a little tempermental the last few start ups... runs great though. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-20-2004, 02:45 PM
1PhatCX's Avatar
it will also run without an o2 sensor, i know because i've done it hehe
Old 09-20-2004, 06:07 PM
ooscgt ooscgt is offline
HI
I have the same problem. I get Code 1. I changed the 02 sensor twice but it did not fix the problem. I checked the wiring but it looks good. The check engine light only comes on after drving over 55mph. Can anybody help???
Also the car seems to be running very rich (no mods. stock motor). I think this problem is related to my check engine light.
Thanks
