Old 09-19-2004, 05:20 PM
lucki17 lucki17 is offline
what kind of amp do i need
alright, i will soon have two 10" diamond audio subs running 1500w rms @ 4 ohms,what wattage amp do i need for these monsters? i know it has to be mono but do i have to run it at 4 ohms? what happens if i run it at 2 ohms? please help, im clueless when it comes to amp's. and does mtx make good amps or should i just stay away from them?
Old 09-19-2004, 06:02 PM
jncodave jncodave is offline
Re: what kind of amp do i need
I assume these subs are DVC (dual voice coil) so if you run them parallel they will be running a combined 4 OHM load. im not sure if you mean that each sub will handle 1500 RMS or both of them combined will handle 1500 RMS. if its the first you want an amp rated at 3000 watts RMS @ 4 OHMS to push both of them. if its the second then you want a 1500 watt RMS @ 4 OHMS amp. FYI just to help you out, the impedence of the amp (e.g. 2 OHM, 4 OHM) is based on the empedence of the subs. since your subs will have an impedence of 4 ohms if run parallel, your amp will be running at 4 OHMS, nothing more, nothing less. hope this helped and i didnt confuse you more.
sorry i dont really know much about MTX so i cant tell you if they are good or not
Old 09-19-2004, 09:36 PM
cody911911's Avatar
cody911911 cody911911 is offline
there is no way in hell ur finding a 3000watt @ 4 ohms that will fit in ur car.
1st rule of drinking and driving.......you gotta have a beer.....
Old 09-19-2004, 09:38 PM
cody911911's Avatar
what exactly are the subs single or duel voice coil ohms? and the above is wrong.
Old 09-19-2004, 11:22 PM
Re: Re: what kind of amp do i need
ok cody, lets go to speaker school. if you run a 4 OHM dual voice coil sub parallel, then it has an impedence of 2 OHMS. therefore if he is running these subs bridged, the total impedence will be 4 OHMS because he has 2 of them. so no i was not wrong. and if you think something is wrong in what i said then you should at least be able to explain what it is and why.
Old 09-19-2004, 11:30 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Re: what kind of amp do i need
that's only true if he wired in series/parallel, parallel/parallel would yield 1ohm, and you're also assuming each speaker is dual 4ohm, if they're dual 2ohm or single 4ohm then that changes everything.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-20-2004, 11:54 AM
cody911911's Avatar
it doesn't necesarrily have to be mono could run a 2 or 4 channel monoblock would probably be the best. What exactly are the subs are they duel or single voice coil subs and what is there impendence. If they WERE duel 4 ohms you could run them parallel parallel to make the 1 ohm load (need one ohm stable amp) and hereby supply more power to the subs, just because the subs may be 4 ohm coils doesn't mean your amp has to run at 4 ohms as long as its stable for the load your giving it.
Old 09-20-2004, 12:13 PM
cody911911's Avatar
and running the subs at 4 ohms and trying to get 3000 rms is a rediculous idea, running a 1 ohm amp say 1500rms@ 1 ohm would be MUCH cheaper than buying a 1500 rms@ 4 ohm (would be huge), why would you want to run the subs at 4 ohms? its rediculous when you can supply more power with less ohms.
Old 09-20-2004, 12:46 PM
cody911911's Avatar
OK... So back to getting something accomplished, You can run an amp at any load (proveded its stable to that load) What we first need to know is if they are single voice coil or duel voice coil before we can make any REAL recomendations on an amp because the subs do dictate the load that your amp will see as well as the way it is wired. It will be easier and cheaper to get the amp running at a lower ohmage (this will supply more power than it would at say 4 ohms). What are the impendence of the subs? What is the RMS rating for each sub or each coil?
Old 09-20-2004, 02:53 PM
sr20de4evr's Avatar
mono means 1 channel, there's no such thing as a 2 or 4 channel monoblock because that goes against the definition of a "monoblock"
I don't know where you keep coming up with this....why would a 1500x1 @ 4ohm amp be any larger or more expensive than a 1500x1 @ 1ohm amp? All it does is step up the voltage twice as high, and it only has to support half as much current....hell it could actually be smaller because the heatsink wouldn't need to be as large.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-20-2004, 03:59 PM
cody911911's Avatar
ya well thats what i said i forgot a parenthesis is all. or a period, don't worry about my spelling to much or grammer.
Old 09-20-2004, 04:08 PM
sr20de4evr's Avatar
ahh alright I see what you were saying now, funny how big of a difference such a little mark makes
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-23-2004, 03:02 PM
okay these are all the specs i could get on the subs, now dont froget im running two of them. i hope this helps a little
Sensitivity: 90 dB
RMS Power Range : 1500 Watts
Impedance: 4 Ohm
Low Frequency response: 23 Hz
High Frequency Response: 250 Hz
Diameter: 10 Inch
Kevlar Nomex sandwich cone
Die Cast aluminum basket
Neodynium magnet
huge dual voice coils
Dual spiders with woven tinsel leads.
Power(W RMS):1500
Impedance (ohms): Dual 4
Sensitivity (dB SPL): 90 (2.83-V input @ 1 meter)
Freq. Resp: 23Hz-250Hz(±3dB)
Diameter: 10"
Depth: 8.9"
Old 09-23-2004, 03:30 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
techincally you would need two 1500 rms amps at 2ohms. I know I am going to get shot for this, but I am going to recommend an amp that is not popular at all.
http://www.cardomain.com/item/BOSC3000D
or a
http://www.audio-direct.com/cgi-bin/...?itemnum=ZRS-9
ZRS-10
www.cloudcity.deviantart.com
Old 09-23-2004, 03:43 PM
cody911911's Avatar
could look at the hifonics 1800d, would be underpowering however.
