Old 09-19-2004, 04:25 PM
Killa's Avatar
Killa Killa is offline
Help my car is SQUEEZE when i turn it on ??
hi , it never happent in the morning when i turn it on , but when i get it run and then stop for about 30 min , i turn it on again , then it squeeze for about 3 second , that scrare me , thanks .
Old 09-19-2004, 04:49 PM
Andydg Andydg is offline
Re: Help my car is SQUEEZE when i turn it on ??
I assume mean squeaks??? If so I think it could be one of the accessory belts.
Old 09-19-2004, 05:25 PM
Killa's Avatar
hi , do you know where it locate ? thanks
Old 09-19-2004, 06:33 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
yeah i would check the belts
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 09-19-2004, 07:08 PM
Killa's Avatar
about 3 month ago i did change a pully belt and air condition bell , but i never change timming belt , but the guy say it was still look new , so i dont change it , but is there a spray that i can spray on the belt and reduce the noise ? thanks.
Old 09-19-2004, 09:47 PM
macder macder is offline
Send a message via MSN to macder
First try checking which belt is squeking (either alternator, power steering or ac belt), once you figure out which belt it is, try tensioning it. These belt have a tedency to loosen after being replaced(on my car anyways). To check the tension of the belts, take the belt and try to rotate it(as if you where trying to flip it inside out), you shouldnt be able to go past 90 degrees. Now if the doesnt help replace the belt, not a good idea to sray anything on it, the belts are not the expensive.
Old 09-20-2004, 12:28 AM
o0_the_0ne_0o o0_the_0ne_0o is offline
Banned
Send a message via AIM to o0_the_0ne_0o Send a message via Yahoo to o0_the_0ne_0o
dude killer at least try to speak properly
Old 09-20-2004, 12:41 AM
george536's Avatar
george536 george536 is offline
o0_the_0ne_0o ithink your sig is a little too big. check on joe with that
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 09-20-2004, 03:09 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
yes it is too big... post the pictures side by side atleast...
Old 09-20-2004, 05:03 PM
Re: Re: Help my car is SQUEEZE when i turn it on ??
Just in case you may have not noticed, we are typing, not speaking. Just wanted to make sure you are clear on that.
Old 09-20-2004, 05:21 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Don't use the belt dressing/spray...It is only a quick fix... just tighten the belts and go.....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
