Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-19-2004, 02:15 PM
DeleriouS's Avatar
DeleriouS DeleriouS is offline
Send a message via AIM to DeleriouS
Turbocharging LS...gsr or ls tranny?
have a 95 LS teggy. i wanna know if anyone smart can tell me what tranny i should go with when i turbocharge my car. i can either keep the stock tranny, or i can put my JDM b16hyd (gsr)tranny with lightend flywheel and stage 3 clutch. I have heard two different stories. 1. the ls is better because of its wide ratio tranny and you want the for a turbocharger app because of spool. 2. i also heard from another person that i should use the gsr tranny because its close ratio and will help for faster spool up, and most factory turbocharged cars have close ratio trannys. can someone please help me with this???
95' LS Integra
5spd
DC Header (4-2-1)
HKS Super Dragger Exhaust
Skunk2 Short throw shifter
Ground Control Coilovers
Strut Bar
-SOON to be putting in a JDM B16 hydraulic tranny with lightened flywheel and stage III clutch
-SOON to be "home made" turbo charging (goal = 12psi)
-GOAL = 250-300hp with stock internals(probably not reachable)
Old 09-19-2004, 05:44 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Turbocharging LS...gsr or ls tranny?
No time in the search for being faster has a longer geared tranny made that happen. The simple fact is the shorter the gears, the faster the car (given they are otherwise the same).
