Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-19-2004, 01:08 PM
protege2.0 protege2.0 is offline
Help please!
My 1997 Maxima GXE Auto with C&C Package
Okay, so the starter went out in my Max and while I was replacing that I pulled the throttle body and cleaned it, replaced the plugs, fuel filter, and air filter along with a oil change and a basic spring cleaning of the engine bay. Well, I put everything back together and took her for a spin. What a difference in throttle response due to the excessive build up of gunk in the TB. But I got a CEL. So, thinking I did'nt plug something back in I begin rooting around th engine bay and discover that all the fuses in the little fuse box to the right of the battery are all wrong (i.e. 7.5 fuses where 15 amp fuses should be so I rearrange all of them and put them in the appropriate spaces as per the diagram on the fuse box cover. Then I reconnect the battery and that is where the trouble begins. The security light is just blinking the car will not start, the radio does't come on when you turn the key all the way forward, nothing. The doors unlock and lock but not with the remote. The headlights come on too but I have looked all over the net and found nothing. What did I do? Is the diagram on the fuse box cover wrong? Is ther a way to reset the security system. Please help or I will have to have the car towed a very long way to the dealer. I should have just left the damn check engine light alone and went to autozone to get the code checked. Help please!
P.S. I washed the engine bay with a damp rag I did'nt spray any components down or get anything really wet.
Old 09-23-2004, 07:41 PM
sidzorn's Avatar
sidzorn sidzorn is offline
Send a message via AIM to sidzorn Send a message via Yahoo to sidzorn
Re: Help please!
u were probably holding the box backwards and when u try to start it move the key up or down even wiggle it also check the right strut tower for broken wires
96 gt bbk x-pipe lakewood traction bars american thunder cat back march ram air k&n richmond gears
97 maxima in progress
