Old 09-19-2004, 12:42 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Fan to help Air
I had a dream... would this work/help?
Would adding a electric fan, small but not too small, in the engine compartment help air flow?
Just some common snese and reasoning: You make it close to the ground, blowing air up. Air being blown gets dense and cold, especially since its coming from the ground. Cold air goes around the engine compartment, blowing the hot air out. Engine compartment drops in temp, intake gets kept cooler, cold air going into the intake.
I cant imagine it helping TOO much in the way of performance, but it seems it should help keep the engine and engine compartment cooler.
Just a thought. Please comment. Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-19-2004, 12:50 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: Fan to help Air
I think they invented that already. It comes in every car I'm pretty sure its not goin to do anything. Doesn't hurt to try.
Old 09-19-2004, 10:58 PM
Rufe Rufe is offline
I think you would be better off designing a vent system, (you want to remove the hot air as opposed to circulating it). Your speed at 50mph would give you 1,000 times the airflow of a fan, (no, that number is not scientific, but it gets the point across)
Fans are better for insuring airflow through the radiator at idle/low speeds.
Old 09-20-2004, 01:28 PM
david-b's Avatar
Dave is THAT guy
Re: Fan to help Air
So lets just say, for example, get a CF hood with vents (not that fake look-a-like), and then have a fan at the bottom blowing air toward the hood.
I know this shit probably sounds stupid, but it's just to get people thinking... mostly me tho.
75 Monte Carlo
Old 09-20-2004, 01:39 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Fan to help Air
intake air temperature doesn't make a HUGE difference, not as much as the intake companies would try to make you think. The main advantage from that would be that the engine as a whole would run cooler because more air would pass over the radiator.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-20-2004, 03:03 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Re: Fan to help Air
Wrong. The colder the air the more dense it is. the more dense it is, the better it will work in your engine. There is a reason air intake companies make those claims; they actually researched and tested it. Why do you think they make cold air intakes? Because they stick out and get colder air than the short rams. And why would people put dry ice on their filters and intake piping at the track? That's right, cold air
Old 09-20-2004, 03:19 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
well it probley dosen't effect things much if the engine compartment is 200F+ just as long as you can get cool air into the intake.
I disregard my perceived image in the persuit of knowledge.
Old 09-20-2004, 08:11 PM
civichatch982 civichatch982 is offline
Re: Fan to help Air
yea I'm roughly going ot have to agree with everyone on this, your fan theory isn't neciserily going to work, and even in the slightest instance that it did keep the engine slightly colder .. the only way that'll help if you end up leaving your car idleing for a very very long time, because engineers took engine cooling into consideration already and therefor they made sure that there was an overly adiquite air flow in the engine bay while driving, and what the air couldnt cool they solved by putting on that nice little cooling system called a radiator.
but .. your idea would work with an enclosed amp (like mine). It works like a charm for the most part, given I just have a small 2.5" computer fan pulling cold air into the encloseur and one pulling the warm air out, therefor creating a nice little air current over the amp and its heat displacers.
Old 09-21-2004, 10:52 AM
drdisque's Avatar
Re: Re: Re: Fan to help Air
because most car "enthusiasts" don't really understand the actual physics of an actual car in the REAL world, they read what the companies put out there that uses theoretical situations and fudged and/or fake dyno numbers into selling them the intake that costs more money. Just because somebody sells something or does something doesn't mean it actually works. Lots of people buy the tornado, that doesn't mean that useless peice of shit actually does anything. Also, I never said cold air does NOTHING, i just said it does very little.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 09-22-2004, 09:35 PM
383PhoenixAm's Avatar
383PhoenixAm 383PhoenixAm is offline
Send a message via AIM to 383PhoenixAm Send a message via MSN to 383PhoenixAm
Re: Fan to help Air
The fact is that you want to get as much cool air as possible. Aside from giving a denser charge to the engine, it also helps in keeping combustion chambers a bit cooler, etc. The problem with the fan idea, though, is that it would probably be a bit hard and impractical to create a fan that could displace enough air to feed engines at the more mid RPMs. At higher RPMs it would probably even be a restriction, not to mention, as Rufe said, at a certain apeed you'd be better off without it. You'd need some sort of centrifuge to do anything like that.
And yes, vents are normally more for getting rid of hot air, not introducing cold air.
Old 09-23-2004, 02:46 AM
benchtest benchtest is offline
david-b
Old 09-23-2004, 02:58 AM
david-b, A radiator is capable of producing in the range of 50,000 watts of heat. That's over 100,000 btu/hour. Imagine a window fan trying to cool your house with the furnace at full roar. The vented hood is a good idea for cooling the engine compartment, but it will have a very minor effect on the intake air tmeperature. Your idea is good, but hard to execute. If you're really concerned about intake temps, you could insulate your cold-air intake.
Best of luck
Old 09-24-2004, 06:38 PM
david-b's Avatar
Dave is THAT guy
Re: Fan to help Air
Thank you. that was all i needed
75 Monte Carlo
